A small disappointment - Router Forums
post #1 of 5 (permalink) Old 04-13-2011, 08:14 AM Thread Starter
RouterForums.com User
harrysin's Avatar
First Name: Harry
Default A small disappointment
The first shot shows an order that I received last week from Pen Kits, Pen blanks, Clock Kits and wood turning accessories. here in Australia. The beautifully made pen press at only $40.00 made me very happy, on the web site it was described as a drilling and pen assembly jig. Well, the former was no problem, it worked well holding the blanks for drilling, then I read the instruction sheet which stated that in addition to a drilling jig it was a three stage jig for pressing in the brass tubes! This I just couldn't understand because the most common kits have a brass tube that is 7mm outside diameter and we drill a 7mm hole through the blanks so that after super glue is applied to the tube, it's simply pushed in and out a few times to spread the glue then the tube is pressed flush with one end against the bench covered with a tissue, no jig being required.
After the initial disappointment, I decided to do something about it as shown in these shots. I'm now very happy with a beautiful and very useful tool that only cost $40.00.
Harry
harrysin is offline
post #2 of 5 (permalink) Old 04-13-2011, 08:45 PM
N'awlins77's Avatar
First Name: Lee
Hey Harry, looks like a helpful tool. But something caught my eye in the second pick. Is that a metal turning lathe in the top left corner? I looked in your uploads and found a somewhat better picture of it. You called it your pride and joy. I bet it is! Who's the manufacturer, and when you get some time, can you post some additional pics of it. I make my living as a metal cutting tool tech. I work on metal cutting lathes everyday. Well almost everyday. I also work on saws, mills, drills, radial arm drills and boring machines. Any manual metal cutting machines. We have other guys, young guys, who work on the CNC's. Which it crazy when I think about it. CNC repair is mostly changing circuit boards, changing parameters, not much physical stuff. Where as my job working on the manuals is more physical. Pulling sometimes big shafts and gears out of gearboxes. Which you can't get young guys interested in doing such manual labor anymore! ;o)
Any ole way.... That lathe caught my eye and I wouldn't mind seeing more pics of it and learning who the manufacturer is. Also, it looks like there's no auto feed on it, you crank that handle at the end of the lead screw to move the carriage? Or is there some type of auto feed that I can't see. If not, I bet it wouldn't take much to adapt a servo drive on there. Something similar to this --- Enco - Guaranteed Lowest Prices on Machinery, Tools and Shop Supplies
Enjoyed the tour of your shop!!
N'awlins77 is offline
post #3 of 5 (permalink) Old 04-13-2011, 09:02 PM
Harry,
When are the additions to the shed planned........LOL
Sydney, Australia
jw2170 is offline
post #4 of 5 (permalink) Old 04-14-2011, 09:22 AM Thread Starter
harrysin's Avatar
First Name: Harry
I appreciate your interest, the lathe is a Myford ML7, probably the most popular model makers lathe ever made. Production commenced in England soon after world warII, in 1946 and continued until 1979, a span of 33 years. My particular machine was made in 1947! Using a set of change gears it can cut Imperial and metric threads and so does have auto traverse and a thread catcher. These shots that I took today explains it all. The lever to dis-engage the rotation simply removes tension from the drive belt. Parallel to the production of this model there was the "super 7" which had a quick change gear box and a clutch drive. Quite recently I saw a Super 7 that looked in immaculate condition going for $6000.00 and I was really tempted but then realised there was no point being in my 78th year.
Harry
harrysin is offline
post #5 of 5 (permalink) Old 04-14-2011, 09:20 PM
N'awlins77's Avatar
First Name: Lee
Verry cool, Harry! The handwheel on the end of the leadscrew through me off, as to it having auto feed capabilities. Never seen an old lathe, here in the states with one there.
It kinda reminds me of a vintage South Bend lathe, made in South Bend Indiana here in the states. The first South Bend, was made by the founders (Twins born in Ireland) in 1908. They don't make them like they use too! You can't even get a machine tool built in the U.S. anymore. The company I work for sells manual machines imported by Taiwan and the CNC machines come from Korea.
Name:	South Bend lathe.jpg
Setting Up a Small Wood Shop?? Advice Needed? WoodHaven Tools and Woodworking 63 08-31-2017 02:45 AM
Cutting small external radi don't look like circles more like small hexagons TroyB CNC Routing 6 06-22-2010 09:03 AM
Routing small pieces of timber colbra General Routing 11 07-01-2009 06:51 AM
small pieces fishlore Table-mounted Routing 58 11-21-2007 07:23 PM
routing small pieces zxxer12 General Routing 9 03-21-2005 03:40 PM
