sliding dovetails - Router Forums
post #1 of 4 (permalink) Old 04-21-2011, 01:50 PM Thread Starter
First Name: steve
Default sliding dovetails
Hi, I am new to this site as well as working with some jigs, specifically the porter cable 4210. So, I am a little confused as to how to set the tenon board. In other words how do you determine how far out from the template does the edge of the board protrude? Is there a standard distance for this? I find the router to be a very versatile tool and would like to use it for multiple applications. Thanks for any help.
standfirm is offline
post #2 of 4 (permalink) Old 04-22-2011, 12:18 AM
G'day Steve
Welcome to the router forum.
Thank you for joining us
Sydney, Australia
jw2170 is offline
post #3 of 4 (permalink) Old 04-22-2011, 09:32 AM
Ralph Barker's Avatar
First Name: Ralph
Positioning of the tenon board in relation to the template is a little tricky, since there are several variables that affect the fit of the DT tenon within the DT dado. As such, you may want to "sneak up" on the proper fit, so as to avoid cutting the tenon too narrow/loose.
I'd suggest starting by marking the center of the tenon board across the end. Then, mark a pair of lines on either side of the centerline that are 17/64" from the centerline (assuming that you're using the standard 17/32" DT bit). The second pair of lines will be the approximate location of the outside edges of the tenon, 17/32" wide. Position the template so the first pair of cuts will be outside those marks, resulting in a tenon that is wider than needed. Then, move the template slightly toward the face of the jig, and make a second pair of cuts, and check the fit. Repeat as needed, reducing the amount of turn on the template positioning knobs with each pass, until you get the proper fit.
Transferring the outside marks to the side of the board will help in "eyeballing" the position of the bit.
The "proper fit" is difficult to describe, however. You should be able to push the tenon board all the way to the far end of the dado with moderate hand pressure, no mallet-tapping should be required. Remember, the glue will take up a bit more of the space, so the dry fit needs to be in the "Goldilocks" zone - not too tight, not too loose. Doing practice joints on scrap will help you to develop a feel for the amount of pressure needed at the dry-fit stage.
Note, too, that different species of wood will have different friction coefficients. But, practicing on (less expensive) Poplar of about the same width as the actual project should get you close.
- Ralph
Ralph Barker is offline
post #4 of 4 (permalink) Old 04-22-2011, 10:05 AM
Hi Steve
The best jig for sliding dovetails.....is the OP jig, it can also do so much more.
See video on the web page below.
Oak Park Enterprises Ltd.: Catalogue
Sliding dovetails for cabinet constuction? Drugstore Cowboy Tools and Woodworking 19 06-05-2012 03:03 PM
Sliding Dovetails nikki1492 General Routing 30 01-13-2010 04:43 PM
sliding dovetails on long boards Neanderthal Portable Routing 5 09-21-2007 08:42 AM
Wall Shelf w/ Sliding Dovetails Joe Lyddon Show N' Tell 45 08-15-2007 08:25 PM
Sliding Dovetails scrollwolf Table-mounted Routing 2 09-12-2004 09:59 PM
