Louver Jig - Router Forums
post #1 of 18 (permalink) Old 06-08-2011, 12:24 PM Thread Starter
Default Louver Jig
Good day to all, I am looking for plans to make a router jig to make louvers for small cabinet doors. I do not have a PHD in woodworking but do enjoy the hobby, this one is for my boat. Thanks
allistair is offline
post #2 of 18 (permalink) Old 06-08-2011, 01:24 PM
Hi
Here's just one of many ways.
post #3 of 18 (permalink) Old 06-08-2011, 03:35 PM
mpbc48's Avatar
Welcome Allistair,
On the outside chance that you could use effect without function, this is an option;
Louver Router Bit - Rockler Woodworking Tools
Check out the video on the page for use.
You think I'm crazy? Wait till you meet my imaginary friends.
mpbc48 is offline
post #4 of 18 (permalink) Old 06-08-2011, 10:27 PM
CanuckGal's Avatar
First Name: Deb
Bob Is part of that PDF missing? I only see one page????
I measured, I marked, I cut.
CanuckGal is offline
post #5 of 18 (permalink) Old 06-09-2011, 11:07 AM
CharleyL's Avatar
First Name: Charley
I would expect that the slanted slots for the louver blades to fit into, are what you are finding difficult.
On the chance that you might have one or have a friend who has one, the Leigh FMT mortise and tenon jig can cut the slots for the louver blades to fit into. A special template is available for making these louver cuts.
Norm Abram did a show where he made plantation shutters and the show is still available on DVD. He made some jigs for this that may apply to what you are doing. He doesn't make the slots for the louvers as the plantation shutter blades are designed to pivot open and closed, but there are tips for making the blades in the video.
New Yankee Workshop - New Yankee Workshop Collection - Plantation Shutters
You might also consider making a jig with a slot at the correct angle for you to fit a router bushing into. This could then be attached to a board that you clamp to the side of your work. You then insert the router bushing into this slot and plunge cut the slot with the appropriate router bit. If I was making this jig I would carefully mark the outline of this slanted slot on a piece of 1/4" hardboard and then carefully cut it out with a scroll saw. Once cut it could be positioned over your work and then tacked to the board that you would use for clamping it to your work. If it worked out well, you might even consider making one with many slots in it so you don't have to re-position it for each cut. You also need to realize that you will need to remove the clamping board and reverse the template board to make the cuts in the opposite side of the louver (right side - left side).
To make the blades I would mill the stock to the correct thickness and width. Then I would use a bull nose router bit of the correct size in my router table with feather boards above and on the edge of the work to hold the stock in the correct position against the table and the fence as I fed the stock past the router bit.
Charley
CharleyL is offline
post #6 of 18 (permalink) Old 06-09-2011, 11:09 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Yes, it is one of a set I posted a while back.
Cheers
Peter
istracpsboss is offline
post #7 of 18 (permalink) Old 06-09-2011, 11:37 AM
Country: Croatia
First Name: Peter
Cheers
Peter
Forgot to add this one.
Cheers
Peter
post #8 of 18 (permalink) Old 06-09-2011, 12:48 PM
Do they need to be functional or just give the look?
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #9 of 18 (permalink) Old 06-09-2011, 12:58 PM
mpbc48's Avatar
Hi James,
Since it's a cabinet door, my guess is they wouldn't need to function. A louver bit would certainly be an easier way to go.
mpbc48 is offline
post #10 of 18 (permalink) Old 06-09-2011, 11:12 PM
CanuckGal's Avatar
First Name: Deb
Thanks Peter!
First Box Joints w/a Hart Design Jig Wild Rag Jigs and Fixtures 2 03-23-2009 08:54 AM
