Need Help With A Bit/Bushing Combo - Router Forums
post #1 of 5 (permalink) Old 07-02-2011, 11:39 AM Thread Starter
AzViper's Avatar
First Name: Keith
Default Need Help With A Bit/Bushing Combo
I have a question I am hoping someone can answer. I am having an elliptical poker table cut on a CNC router using a 1/2" double fluted bit. The center cutout as seen in figure C will be 71" by 22" on the outer edge and the leftover piece should be 70" by 21". I need to use this 70" by 21" as a template to cut a slightly larger center piece of 70"-3/8" by 21"-3/8". What router bit / bushing combination should I use it there is such a combination. In the past I would just cut this using my circle jig but I am now having to use a bit / bushing combo as I need to use a template due to being an elliptical cutout.
I would have used a 1/2" shank bit that had a cutting surface of 5/16" by 1" on the CNC router as this would leave the cutout with the 5/16" gap I need, but I cannot find a bit locally without ordering it and with the holidays upon us I need it for next Wednesday. My only option is to use a bit / bushing. With elliptical if we were to set up the CNC router to make this cut the outside edge will not maintain a 5/16" gap once this center section is placed back into the original cutout due to the inherited issues with elliptical cutouts.
Hope this makes sense. When building a poker table we have what we call a racetrack table with a center playing surface as seen in the photo. Its the gap between the racetrack and the center playing surface that I need to maintain a 5/16" before foaming and applying the cloth.
AzViper is offline
post #2 of 5 (permalink) Old 07-02-2011, 12:45 PM
Phil P's Avatar
First Name: Phil
Hi Keith
3/8in overall larger translates to a 3/16in offset from the edge of template to the cutter. The router cutter combination needs to be diam of router + 2 x 3/16in; so your 1/2in cutter could therefore work with a 7/8in guide bush, if you can get one that is. Alternatively a 3/8in cutter would achieve the same effect with a 3/4in guide bush, and I know they're available.
I think that makes sense
Regards
Phil
Phil P is offline
post #3 of 5 (permalink) Old 07-02-2011, 12:58 PM Thread Starter
AzViper's Avatar
First Name: Keith
Originally Posted by Phil P View Post
Hi Keith
Regards
Phil
Thank you Phil. I have entire set of bushings and I have both the bushing you spoke of. Good news though, I found a 1/2" shank bit with a 5/16" x 1" cutter. This completely solves my problem as the router vacuum will suck the plywood down and the 5"16" cutter will leave me the 5"16" gap I need without buying another sheet of plywood and using the bit / bushing combo with the template.
AzViper is offline
post #4 of 5 (permalink) Old 07-02-2011, 07:45 PM Thread Starter
AzViper's Avatar
First Name: Keith
Well after speaking to my friend who owns the CNC router what he told me makes more sense then buying the 5/16" router bit. He is going to write the program to plunge cut with a 1/4" bit making multiple passes to cut through the entire sheet. Then on the racetrack side of the plywood with the CNC router bit at its full depth to trim 1/32" off and repeat this on the center section to give me my 5/16" gap. He says you never want to plunge a start and stop but to do a circular lead in with a cutter as the finish product is better and will have a smoother finish.
Bottom line I have been beating myself up over this when he had it under control...
AzViper is offline
post #5 of 5 (permalink) Old 07-03-2011, 04:25 AM
Phil P's Avatar
First Name: Phil
Hi Keith
Ramped entry cut is smoother and places less strain on the cutter as well. Also allows you to use a non plunge cutter for what is essentially a plunge operation
Regards
Phil
Phil P is offline
Rigid Model R2900 Router Combo and Ryobi Model A25RT02 Router table bigdave720 Table-mounted Routing 12 04-05-2012 07:27 PM
Milwaukee 18V drill+driver combo crquack Tools and Woodworking 1 03-05-2010 06:17 AM
Craftsman Combo bill0199 General Routing 17 06-20-2009 09:25 AM
Ridgid Router Combo R2390 homebrewer27 General Routing 28 04-28-2008 09:45 PM
Stapler vs. Nailer/Staple combo rprice54 Tools and Woodworking 4 06-08-2006 06:39 PM
