cutting a circular opening - Router Forums
post #1 of 9 (permalink) Old 07-09-2011, 04:06 PM Thread Starter
First Name: Shawn
Default cutting a circular opening
So the reasoning for joining is my project is building a table for my Green Egg BBQ.
The table top will be made out of 5/4 cedar decking boards and I need to cut a
circle inside the table measuring 26 1/4 " . I want this to be a clean cut and neat
when finished . I figure a router circle jig would give a neat clean cut. So my
question is keeping in mind I have used a router once in my life!
Can a router be used to cut an opening of this size as well as able to cut an opening.
I have seen circle jigs used to cut circles and use the inside part. I need to use the router to cut this round opening. I hope this makes sense. Being a new member I
can not post links but if anyone wants some more info and is willing to help that
would be great . You can google Big Green Egg table plans and go to the website
under table plans. If anyone has any other suggestions it would be appreciated
Shawn
Green Egger is offline
post #2 of 9 (permalink) Old 07-09-2011, 04:47 PM
Hi Shawn
The router will do a great job,you just need to make a simple cir. jig out of some scrap plywood.. for a one time thing.
http://texd.com/bge-table.pdf
Shawn
post #3 of 9 (permalink) Old 07-10-2011, 06:21 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Shawn
Make a larger version of this simple jig and rout in steps of no more than 1/4". The bit size isn't critical but 3/8" would be perfect.
Harry
harrysin is offline
post #4 of 9 (permalink) Old 07-10-2011, 09:11 AM
A simple board with a hole for the bit and a nail on the other end should work well for you.
post #5 of 9 (permalink) Old 07-10-2011, 09:17 AM
harrysin's Avatar
First Name: Harry
Isn't that what I suggested Bob?
Harry
harrysin is offline
post #6 of 9 (permalink) Old 07-10-2011, 10:04 AM
Shawn,
Hopefully your router is a plunge router, it can be done with a fixed base router but it's a lot simpler (and a tad safer) with a plunger.
(edit) You'll also need to figure a way to control the cutout as you finish the cut, ie. keeping everything from falling through the hole you just made.
If you cut it on a flat surface, remember that the router bit will cut into that surface. If you cut the hole after your table is complete tack, clamp, screw or whatever a couple of scraps to support the cutout.
Harry,
I can't open your zip files for some reason, anything special about them?
TomE is offline
post #7 of 9 (permalink) Old 07-10-2011, 12:27 PM Thread Starter
First Name: Shawn
[QUOTE=TomE;242233]Shawn,
I have access to an old fixed B & D router but are looking at purchasing a router for
this job and for other projects around the house. A plunge router would be way easier
of tackling this job.
Thanks for the idea of tacking the cutout . Nothing more fustrating than spending time cutting a board or an opening like this and have it destroyed and broken into
pieces making it useless.
Thanks as well to everyone else that has replied and responded so quickly !
Any other input anyone has will also be considered
post #8 of 9 (permalink) Old 07-10-2011, 07:02 PM
Here's a quick trammel arm I made to route a 60" tabletop. The router I used was a Porter Cable 690 with a 1/2" straight bit. No need for a template guide. I used a 1/4" piece of MDF cut to 48"L x 5-3/4"W. I drew a line down the middle for measurement (2-7/8") of different radius's. Drill a hole larger than your bit for clearance center of where you bit is located. Use the router plate for hole mounting locations & mount MDF trammel arm in it's place.
To route an outside circle I measure to the front side of the bit. For an inside radius I measure to the far side of the bit. I use a nail as a pivot point & locate it half the distance of radius needed. I routed from the bottom so nail hole from the pivot would not be seen or damage the top side. The tools for routing out circles are probably just laying around in your shop as scrap.
Name:	Quick Trammel for circles 001.jpg
Name:	Quick Trammel for circles 002.jpg
Name:	Quick Trammel for circles 003.jpg
Name:	Quick Trammel for circles 004.jpg
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #9 of 9 (permalink) Old 07-11-2011, 03:54 PM
First Name: stuart
how did it go then
any photos
stuart
stuartwatson is offline
Cutting boards for gifts.... gad5264 Project Plans and How To 16 08-17-2016 07:35 AM
Where can I find this Slick method for cutting router plate opening into table Peter Sanders Table-mounted Routing 25 10-17-2015 01:57 PM
New router and which starter router bits for my useage? Skyglider Router Bits - Types and Usage 11 12-08-2010 09:42 PM
cutting 3" circular recesses Grung56 Guide Bushings and Templates 9 08-30-2010 09:28 AM
