best router baseplate - Router Forums
post #1 of 8 (permalink) Old 07-11-2011, 11:02 PM Thread Starter
joe beaty's Avatar
First Name: Joe
Default best router baseplate
what is best router base plate to match the porter cable bushings (dovetail jig 4216) with a dewalt 621 router?? i bought the router at a pawn shop, it has no baseplate with it
joe beaty is offline
post #2 of 8 (permalink) Old 07-11-2011, 11:12 PM
Hi Joe
I suggest you get the plate below, killing two birds with one stone thing, you can use the guides that come with the plate or use the PC type guides with it.
Amazon.com: Milescraft 1211 Base Plate Metal-Nose Bushing Set for Routers: Home Improvement
http://www.amazon.com/Milescraft-120...m_cr_pr_sims_t
post #3 of 8 (permalink) Old 07-12-2011, 09:29 AM
Joe, you can buy a sub base plate from DeWalt parts online; you can also build your own sub base plate, instructions are available in one of the Sticky threads.
post #4 of 8 (permalink) Old 07-12-2011, 09:45 AM
Hi
Just a add a note to Mike's post, if you make your own you will need to buy a 1 3/16" drill bit if you want to use the PC type guides, if you are going to make more than one it's the best way to go , the 1 3/16" bits are not in most sets, you can get the set for about 100.oo bucks or just the one bit for 9.oo to 30.oo bucks but it's must have item if you want to make your own..
Amazon.com: 31-Piece Forstner Bit Set with Case: Home Improvement
Amazon.com: 1-3/16" BORMAX Forstner Style Bit: Home Improvement
Forstner Bit Set - Peachtree Woodworking Supply
post #5 of 8 (permalink) Old 07-12-2011, 12:58 PM
Phil P's Avatar
First Name: Phil
Hi Joe
There's possibly an alternative. Buy a Leigh (as in dovetail jigs) #706R adaptor. This will allow ypou to mount a P-C guide bush in a DW621
Regards
Phil
Phil P is offline
post #6 of 8 (permalink) Old 07-12-2011, 07:47 PM Thread Starter
joe beaty's Avatar
First Name: Joe
thanks Phil, do you know for a fact that it will fit the 621 DeWalt??
post #7 of 8 (permalink) Old 07-13-2011, 08:53 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Originally Posted by Phil P View Post
Hi Joe
Regards
Phil
You may be able to get a free one. DW routers stateside often come with a PC adaptor in the box.
I emailed DeWalt and said there wasn't one with my DW625.The lady was most helpful and didn't even ask me where I'd bought it, or whether I'd lost it. All they needed was a US address to deliver it to, which I was able to give them.
The Leigh mounting plates are fine. They make them for most makes of router.
Cheers
Peter
istracpsboss is offline
post #8 of 8 (permalink) Old 07-13-2011, 02:06 PM
Phil P's Avatar
First Name: Phil
Thanks Peter, I'd forgotten that DW supply a guide bush adaptor in the USA for the DW625, but I wasn't sure about the DW621. As to the Leigh adaptor, Joe, I can't say for absolute certain as I'm not a DW621 user. Having had a Leigh D-4 jig in the past I can say for certain that Leigh's adaptors for both the DW613/DW615 and DW624/DW625 work with their respective routers and take a standard Porter-Cable guide bush. Leigh's guide bushes are standard P-C guide bushes, and I've also used them in my own P-C 691 D-handle. Leigh have been in this market for over 20 years and are a respected supplier, so I can't see them making unsubstantiated claims for their (excellent) product
Incidentally according to eReplacementParts the part number you are looking for is #329120-01 - a massive $7.45, although it's on 1-2 weeks delivery (BTW, the Leigh part is often ex-stock)
Regards
Phil
Phil P is offline
Router Recall (PC, SEARS, RYOBI) Birdflu General Routing 5 02-23-2012 10:01 PM
Router table or Plunge routing template tom Guide Bushings and Templates 15 04-14-2009 02:45 AM
