Clock Movement Jig - Router Forums
 2Likes
post #1 of 20 (permalink) Old 07-14-2011, 08:25 AM Thread Starter
Default Clock Movement Jig
Hi,
Just checking to see if anyone would know if there is a jig made for the following.
I have long lengths of Cherry hardwood that I cut down to make clocks. The width of these parts vary - and I need to route 2 1/2" square pockets in the back of these to place the movement into. I drill out the center for the shaft to go through - so I need to place the bit to the center - then cut 2 1/2" around this. I was going to make a frame to place over this and clamp it each time - but I am not sure if there is something made already to make it easier.
Tom
maldak is offline
post #2 of 20 (permalink) Old 07-14-2011, 08:50 AM
Hi Tom
Not that I know about but no real standard for the size of the movements.
I use a 3 1/8 Forstner bit for that job,it's only 20 bucks and gives me a little bit of adjustment for the movement and it's easy to center it in place..almost all the movements fit right into the round hole.
It's one of the items you don't see from the front of the clock, pie is sq.but round is fine for clocks. and it's quick and easy..and always very true.
Forstner Bit Set - Peachtree Woodworking Supply
Originally Posted by maldak View Post
Hi,
Tom
post #3 of 20 (permalink) Old 07-14-2011, 09:27 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Hi,
Tom
These shots from a couple of my earlier forum projects show how easy it is.
Gaffboat likes this.
Harry
harrysin is offline
post #4 of 20 (permalink) Old 07-14-2011, 09:39 AM
Hi Harry
Very nice, but who is going to see it other than the wall drill bit easy .all done with just one drill bit..no tape or clamps needed ..
post #5 of 20 (permalink) Old 07-15-2011, 07:10 AM Thread Starter
Thanks for the help everyone. - Tom
maldak is offline
post #6 of 20 (permalink) Old 07-15-2011, 09:07 AM
harrysin's Avatar
First Name: Harry
Hi Harry
You really have me confused this time Bob. The remark about the wall referred to the imperfection, the drill bit was the same size as the thickness of the clock mechanism and the template was clearly seen in two shots to be clamped in position.
Harry
harrysin is offline
post #7 of 20 (permalink) Old 07-15-2011, 09:32 AM
Hi Harry
Sorry to confuse you, all I'm saying why go down the road with all the templates when one drill bit will do it all in one pass on the drill press, the KISS way.
You can't see the round hole or the sq.hole from the front side of the clock just like the imperfection that you put on the back side..
post #8 of 20 (permalink) Old 07-16-2011, 09:29 AM
harrysin's Avatar
First Name: Harry
Perhaps I just like to put square pegs in square holes Bob! Perhaps Marlene is right when she accuses me of being pedantic.
Harry
harrysin is offline
post #9 of 20 (permalink) Old 07-16-2011, 11:00 AM
Hi Harry
" pedantic "
I would not say that you are a great teacher but if the tools are at hand why not use them just like the Kreg pocket holes screws way, what you can't see you can't see..like many wood joints...they hold just as well and sometimes better.
post #10 of 20 (permalink) Old 07-17-2011, 09:26 AM
harrysin's Avatar
First Name: Harry
Hi Harry
" pedantic "
Perhaps this shot of an award that was presented to me some years ago says it all my friend.
Harry
harrysin is offline
First Box Joints w/a Hart Design Jig Wild Rag Jigs and Fixtures 2 03-23-2009 08:54 AM
