Morticing plate picture doesn't look right. - Router Forums
post #1 of 14 (permalink) Old 08-01-2011, 06:28 PM Thread Starter
mpbc48's Avatar
Default Morticing plate picture doesn't look right.
I posted this in another thread but I don't expect it will be seen because of the title.
When I look at the image;
I don't understand how that plate could have been used to make the mortice in the picture. To me, it looks like the mortice is cut closer to the end of the material than the guide pin could support the centering of the bit. Even with visual deflection caused by the clear plate, the mortice looks to be cut well beyond the capability of the pin in the plate.
In order for this plate to work properly, both pins must contact the sides of the material throughout the cut.
Am I missing something?
The original image is here; Image Gallery
You think I'm crazy? Wait till you meet my imaginary friends.
mpbc48 is offline
post #2 of 14 (permalink) Old 08-01-2011, 10:16 PM
I don't think you missed a thing Mike - nice catch
They would have needed a piece of scrap clamped in that vice also to get that close to the edge.
I made one like this and I need to clamp extra scraps between the clamping plates to get near the end like that:
John Schaben
jschaben is offline
post #3 of 14 (permalink) Old 08-01-2011, 10:45 PM
CharleyL's Avatar
First Name: Charley
It's likely a setup picture that was taken after the board was cut to length. You are right. You can't cut a mortise that close to the end of a board with that fixture, unless you clamp a board to the end of the work to extend it far enough for the guide pin to ride on. Both guide pins have to remain in contact with the sides of the work, or an extension piece for the cut to be made properly.
Charley
CharleyL is offline
post #4 of 14 (permalink) Old 08-01-2011, 11:18 PM
Hi
I have one and a home shop one and they work, look at the snapshot one more time and flip the base plate around in your head..
post #5 of 14 (permalink) Old 08-01-2011, 11:41 PM
Hi
I dunno Bob, I gotta be careful flippin things around in my head, but it still looks to me like the stock either gotta get longer or wider. (clamp a piece on each side).
John Schaben
jschaben is offline
post #6 of 14 (permalink) Old 08-02-2011, 12:03 AM Thread Starter
mpbc48's Avatar
Thanks John,
The scrap piece clamped on makes sense.
mpbc48 is offline
post #7 of 14 (permalink) Old 08-02-2011, 09:39 AM
Hi
The picture plays with your head a little bit. they will put the slot with in a 1/2" from the end of the board, that's the norm..\But if you want it right to the edge you will need to use some other type of jig like JessEm Zip Slot Mill or the Craftsman..
http://www.routerforums.com/jigs-fix...ge-router.html
post #8 of 14 (permalink) Old 08-02-2011, 10:29 PM
HI John
No need to " (clamp a piece on each side/end) " just stick in some 1/8"or 1/4" MDF on each side of the board and it will pull the bit in.. so to speak.
post #9 of 14 (permalink) Old 08-02-2011, 11:46 PM
HI John
Hi Bob - that's what I was thinkin. I tried jerry rigging a two pin deal awhile back and I guess my co-ordination ain't what it used to be. That's why I made the Wood magazine version. That works pretty well with a 1" bushing and half inch bit. I did have to redo it a couple of times to get my pivots in the right spot to center it.
That General jig looks like it may be interesting.
John Schaben
jschaben is offline
post #10 of 14 (permalink) Old 08-03-2011, 09:16 PM Thread Starter
mpbc48's Avatar
It would be very difficult for me to keep the plate flat on a 3/4" wide surface. Maybe with much longer pins it would work for me.
mpbc48 is offline
Router Plate Installation Rutabagared Project Plans and How To 11 01-14-2012 07:15 PM
Finishing the way I see it! by Derek Willis. derek willis Woodworking Articles 0 02-28-2011 08:44 AM
Welcome to "Show N' Tell" Mark Show N' Tell 0 08-17-2005 04:55 PM
