Ski's-Cupping and Cam Board - Router Forums
post #1 of 3 (permalink) Old 08-07-2011, 09:15 PM Thread Starter
Marco's Avatar
Default Ski's-Cupping and Cam Board
I searched and read the forum for a long time to find the answer of trying to get the cup out using router skis and a cam board so your answer and input is more than welcome,
I didn't find a direct answer but am guessing.......
Place the board with the cup facing down.
Shim the 2 sides so the board won't wobble and start to shave off the high sides
When you get it some what flat sand it then flip it over to get the cup facing up
Start in the middle of the cup and work your way toward the sides until its flat
Sand it and now you have an almost flat board about a 1/3 as thick as when you started?
[B“It’s not a mistake, it’s a design feature”][/B]
Marco is offline
post #2 of 3 (permalink) Old 08-08-2011, 07:21 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
These shots taken form an early photo-shoot of mine should be of help to you. Once the one side is flat, it can either be put through the planer or routed the same way as the first side.
Harry
harrysin is offline
post #3 of 3 (permalink) Old 08-08-2011, 12:58 PM Thread Starter
Marco's Avatar
Thanks Harry and pictures can often explain more than words
Marco is offline
