Mortise and tenons - Router Forums
post #1 of 4 (permalink) Old 08-12-2011, 06:44 AM Thread Starter
Default Mortise and tenons
Hi, I'm a cabinet maker in Cleveland TN. I've been called upon to replace a cathedral window in a church. The wood is about 1 1/4" thick and needs to be routed. How do you rout a rounded surface on the inside of the radius and the outside of the radius?
Secondly, how do join the peak of the cathedral window with a mortise and tenon joint.
Thanks.
Glen
gwintermeyer is offline
post #2 of 4 (permalink) Old 08-12-2011, 07:50 AM
papawd's Avatar
First Name: warren
Welcome
papawd is offline
post #3 of 4 (permalink) Old 08-12-2011, 08:16 AM
Welcome, Glen
Sydney, Australia
jw2170 is offline
post #4 of 4 (permalink) Old 08-12-2011, 04:35 PM
Phil P's Avatar
First Name: Phil
Hi Glen
Inside and outside routing often require two separate templates (one for each side) made after drawing out the window glazing bars full size. These look a bit like the old fashioned sticking jigs used to plane-up sash sticks by hand (although they are obviously curved). I sometims have a similar problem when making curved counters, reception desks, etc. BTW the class of work you are talking about is often performed on a pin router rather than a portable router.
As to joints may I suggest that you try to study the existing joints if at all possible. There are various techniques for jointing glazing bars ranging from end dowelled joints (the 18th century approach) which requires a purpose-made jig to scribe and a second one to drill the dowels to the modern scribed/glued joint approach as shown here which is sometimes supported by glueing a piece of canvas beneath the glazing bars
Regards
Phil
Phil P is offline
Squaring Up Mortise And Glueing M & T Gaia Starting Off 4 08-03-2011 03:24 PM
Bed Constuction using Loose Tenons C+ Woodworker Table-mounted Routing 17 06-09-2010 04:43 PM
TS / Router / Mortise Combo PART1 kolias Jigs and Fixtures 1 05-04-2009 06:52 AM
Tenons on the Router Table rstermer Table-mounted Routing 12 04-24-2008 09:41 AM
Rounded Mortise & Squared Tenons? Nickbee Table-mounted Routing 15 01-16-2008 08:11 PM
