Ez spartan guide turns your circular saw into a tracksaw - Router Forums
post #1 of 4 (permalink) Old 08-18-2011, 12:39 AM Thread Starter
roofner's Avatar
First Name: Gary
Default Ez spartan guide turns your circular saw into a tracksaw
Anyone have experience with these products? There is a sale now 30% off on your order
roofner is offline
post #2 of 4 (permalink) Old 08-18-2011, 06:06 AM
Gary, saw and router guides are a big help when cutting panels free hand. Instead of spending big money for one make your own out of 1/4" Masonite and a piece of 1"x2". Glue and screw the 1"x2" onto a piece of Masonite 12" wide. Using the strip as your guide trim off one side with your saw, the other with a router. It is super easy to clamp this guide to a full sheet of plywood or any smaller panel and you know exactly where your cut will be.
post #3 of 4 (permalink) Old 08-18-2011, 08:46 AM
Gene Howe's Avatar
First Name: Gene
+1, Mike.
Simple is better.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #4 of 4 (permalink) Old 08-18-2011, 09:47 PM
First Name: Randal
What do you want to do with it? If only cut up plywood, it is an expensive sawboard. If a small shop (space), and your not comfortable with a tablesaw (safety), then to me, it was the way to go.
It does require a different mindset, IMHO and experience.
LinuxRandal is offline
Router template inlay V Garry General Routing 7 12-27-2008 06:49 PM
Circular Saw and router guide "Off-set" plate simplenik Tools and Woodworking 9 11-19-2007 10:20 AM
Circular saw guide simplenik Table-mounted Routing 1 06-29-2006 09:05 PM
