Bought a routerlathe - Router Forums
post #1 of 8 (permalink) Old 09-02-2011, 10:55 PM Thread Starter
The Warthog's Avatar
First Name: Roger
Default Bought a routerlathe
The tool was advertised a few weeks ago on Kijiji for $35, and noone was showing any interest, so I finally did and visited the gentleman today and came home with a Sears routerlathe in practically brand new condition, as well as a copy of a Trend manual for the same piece of equipment. I was sold by the opportunity to do flutes and roping, and the very reasonable price.
After reading the manual twice, I am pretty sure I can operate it easily. I'll do most of my turning on a real lathe, but roping and fluting is a capacity I wanted very much to add. Anyone else have one of these? If I have questions, I'll be back to ask them.
Oh, is a plunge router or fixed router best with it? Is there any way to change the 7" per revolution limit for roping? Um, that's all for now...
Cheers,
Roger
I'm not slow, I'm pacing myself!
Isaiah 44:13 Another shapes wood, he extends a measuring line, he outlines it with red chalk. He works it with planes and outlines it with a compass...
Usual kit: Table saw, band saw, dual base router and table, lathe, various saws, planer, sanders, and a multitude of hand tools.
The Warthog is offline
post #2 of 8 (permalink) Old 09-02-2011, 11:18 PM
Hi Roger
fixed router is best but the plunge router will work also ..
" change the 7" per revolution limit for roping?" yes, see the index head cable and the manual
See my uploads for many shots of the lathe
post #3 of 8 (permalink) Old 09-02-2011, 11:30 PM
papawd's Avatar
First Name: warren
Cool for $35, I would buy it just to try it
papawd is offline
post #4 of 8 (permalink) Old 09-04-2011, 08:17 AM
First Name: del
I have one of those and i used a fix base router on it. I have the book with mine also. It is easy to use. Just use a test piece first. Like indexing and router travel ect. good luck on it
del schisler
port st. lucie, florida
del schisler is offline
post #5 of 8 (permalink) Old 01-22-2012, 01:23 AM
First Name: Leo
Default Can't get a level cut from the Router Crafter
I have a Sears Router Crafter and have not been able to get it to plan a level cut. I have adjusted the angle but even all the way down I still get a angle cut.
Any ideas.
ladjr3552 is offline
post #6 of 8 (permalink) Old 01-22-2012, 06:28 AM
Hi Leo
Try this, once you have the stock in the lathe and you have a router in place move it all the way down to the sq.socket end of the lathe ,set the router bit right on the stock and lock it in place then lift the router and move it to the tail end and do the same thing and adjust the center point threaded rod until it's just like the other and than do it one more front and then the tail end..it should dead on center once you have it set fire up the router and make a light cut on both ends it should the same height from the deck if not just readjust the tail end just a little bit..
Hope this helps have fun
Any ideas.
post #7 of 8 (permalink) Old 01-22-2012, 03:14 PM
First Name: Alan
I have one of these too. Although it is the Trend routerlathe over here. I used to use it quite a lot a few years ago but barley twists and flutes have dropped out of fashion over here. It seems everyone want's ultra modern stuff or shaker style. I used to use an Elu 96 plunge router with mine and turned out some great stuff with it. I may get it out agin when I have time to have a play with it. I used to really enjoy using it too.
mailee is offline
post #8 of 8 (permalink) Old 01-22-2012, 04:04 PM
First Name: Leo
Hi Leo
Thanks I will give it a try.
Leo
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 09:33 AM
Tolls you wonder why you bought Ells Tools and Woodworking 9 05-03-2011 12:15 PM
I bought some accessories last night... am I just wasting money? Gweedz General Routing 16 08-05-2010 05:06 PM
Bought some Wood jd99 Wood Species 15 05-30-2010 11:47 AM
I bought a new router , now? larryproctor Table-mounted Routing 2 01-15-2007 10:16 PM
