Building a Circle Cutting Jig - Router Forums
post #1 of 27 (permalink) Old 09-05-2011, 09:52 PM Thread Starter
darrink's Avatar
First Name: Darrin
Send a message via Skype™ to darrink
Default Building a Circle Cutting Jig
I had some time to spend in the shop this past weekend. Our shop was closed on Friday and Monday, so I wound up with a four day weekend. I was burning the midnight oil out in the shop, taking advantage of the time off, and not having to get up at my usual 4:00 AM.
I have been wanting to make some bowls and trays with my router, but needed a way to cut a round hole to make a template. I have also been wanting to make a circle cutting jig, so I set forth to do just that.
This is by no means my design, as a matter of fact, I copied the one that Harry uses, and I know James built one like it. This is just my version, and I thought I would document the build to share, and hopefully help others.
Thanks!
Darrin
Sealy, TX
darrink is offline
post #2 of 27 (permalink) Old 09-05-2011, 11:06 PM
Boy, Darrin, I am jealous...
You put a lot of work into that jig, and it shows.
Congratulations.....
Now we want photos of the bowls.........VBG.
Sydney, Australia
jw2170 is offline
post #3 of 27 (permalink) Old 09-06-2011, 05:37 AM
dutchman 46's Avatar
First Name: Howard
Nice work, Darin! I will copy if You don't mind?
John 3:16
dutchman 46 is offline
post #4 of 27 (permalink) Old 09-06-2011, 07:01 AM Thread Starter
darrink's Avatar
First Name: Darrin
James,
Thanks James!
I do intend to get pictures of the bowls, all the way from making the templates to finishing the bowls.
Darrin
Sealy, TX
darrink is offline
post #5 of 27 (permalink) Old 09-06-2011, 07:06 AM Thread Starter
darrink's Avatar
First Name: Darrin
Thanks Howard! You copy and distribute all you want; if it will motivate someone else to build it, that would be great. The one thing I forgot to add was the distance from the end of the jig to the first pivot hole, and the distances between the rest of them. I will post that information this evening.
Darrin
Sealy, TX
darrink is offline
post #6 of 27 (permalink) Old 09-06-2011, 09:03 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
What a first class outcome Darrin and the photo-shoot, well, what can I say, it's just super.
The one thing that I did differently was the mounting of the rods, which for the Makita 3612/C is 12mm, I actually routed 12mm holes that made the rods an interference fit, and before driving them in I ground flats and drilled 1/4" countersunk holes in the mounting block. After driving in the rods I poured super strength Araldite into the holes and the rods have remained in place during 11 years of regular work.
This shot clearly shows these Araldite filled holes.
Harry
harrysin is offline
post #7 of 27 (permalink) Old 09-06-2011, 09:25 AM
Nice job Darrin. You can heat the Formica with a heat gun so it will bend to shape. Wear gloves to prevent burns; you can cut a form slightly smaller than your opening from scrap wood to help get the shape. You might want to put a slight chamfer on the jig edges; Rockler may still have a PC chamfering bit on clearance for a couple dollars.
post #8 of 27 (permalink) Old 09-06-2011, 09:42 AM
Hi Darrin
Nice job on the jig and the PDF file
At one time back in 2007 I had one like that and then I found out about the Jasper jig and the old cir.jig got reworked for other jobs I don't have the rods and the holding block any more must be on some other jig maybe..
Once you have a Jasper jig you will put all other cir.jigs on the wall..with the Jasper you don't need fix it to the router in anyway it's a simple drop the guide in place and cut the cir.out and it will work on about 95% of routers without pushing any rods in to the base of the router..
Amazon.com: Jasper 200J Model 200 Circle Cutting Jig for Plunge Router: Home Improvement
Amazon.com: Jasper 400J Model 400 Router Circle Cutting Jig: Home Improvement
This is by no means my design, as a matter of fact, I copied the one that Harry uses, and I know James built one like it. This just my version, and I thought I would document the build to share, and hopefully help others.
Thanks!
post #9 of 27 (permalink) Old 09-06-2011, 09:54 AM Thread Starter
darrink's Avatar
First Name: Darrin
Thanks Harry! Yours is much cleaner looking without the nuts and washers, that's for sure. I had contemplated using threaded inserts and set screws to hold the rods in place, but I didn't think the wood would hold up to the pressure exerted by the set screws. Another idea was to use a threaded insert that the rods would thread right into, but I did not have any that size. I remembered that you had epoxied yours in place, but I did not have confidence in that method, but it appears you have proved it does hold up. I was not able to find any 12MM rod locally, so I settled for the 7/16" (~11.11mm).
Anyway, it was an enjoyable build and my dad came over a couple of times when he seen the lights on in the shop and we visited, which is always good.
Darrin
Sealy, TX
darrink is offline
post #10 of 27 (permalink) Old 09-06-2011, 10:36 AM Thread Starter
darrink's Avatar
First Name: Darrin
Thanks Mike! I may try the heat gun on another project. Since I have waxed the MDF, I doubt the contact cement would hold on this one. I used a file to take the sharp edges off of the laminate after I trimmed it with the flush trim bit. Yet another step I left out of the photo shoot.
Darrin
Sealy, TX
darrink is offline
P-Cable Edge guide as circle jig? sourdough Portable Routing 4 05-13-2011 09:24 AM
Circle jig for Colt? sourdough Jigs and Fixtures 2 02-03-2011 03:30 PM
First Box Joints w/a Hart Design Jig Wild Rag Jigs and Fixtures 2 03-23-2009 08:54 AM
Circle jig for Bosch 1619EVS tech406 Jigs and Fixtures 11 02-19-2009 04:36 PM
