EZ Dovetail Jig - Router Forums
 1Likes
post #1 of 13 (permalink) Old 09-26-2011, 01:50 PM Thread Starter
Default EZ Dovetail Jig
Just a quick How To Use the EZ Dovetail Jig
It's great little dovetail jig for the price and it's a very easy jig to use once you set it right.
The video(s) Demo are great but they don't press many important things that you need to do or not do to make great dovetails quick and easy..
The jig will do Blind dovetail in 1/4" to 3/4" thick stock just by adjusting the gray gauge on the right side of the jig..for the board thickness.
The 1st thing you want to do is NOT use the jig to set the dovetail bit (in the router table or your hand router) it's OK but not very true way, you want to use the brass bars, set the bit at 1" high, once you have that set move the brass bars to the right side and set the gray gauge to 1 1/4" for 3/4" thick stock.
Once you have that done don't move the router bit up or down and don't readjust the gray "gauge" one also, it's one time thing needed, set it and forget it thing.. .
Now you are almost set to cut the dovetails pins, you can use 2",3",4",5" wide stock very easy,,move the pin board over the template pins and have some stock hang over the pin, template pins, just a little bit,on both sides ,once you are happy with that clamp a small stop block on the front of the jig,see picture below, this will take the guess work out on the next board settings.
Now cut all the pins on both ends of the sides boards for the box/drawer,once you have all the pins cut for the box remove the stop block on the front of the jig..
Now take the pin boards over to the other side of the jig and place a blank board in the jig, line it up just like in the video, but b/4 you cut the pockets, clamp one more stop block on the inside ,front of the jig, see the blue screws in the picture below, now cut the pocket holes on both ends of the front and back parts , the stock block will help you set up for the next board....quick and easy.
Many forget you don't need the sides of a drawer to be the same size as the hole, 3" or 4" works great without guides, you just need some wood guides in place so the drawer will side in and out easy but not drop out or down once you pull it open..
You will note the pins are almost sq. unlike many dovetail jigs it's almost a box joint but it's good dovetail joint that you can only see the one part of the joint like many dovetails are..
And yes this is done with a trim 1/4" router no need for a big router with dovetails..
One more note::::: be sure to check the pocket holes b/4 you remove the board ..that's the only part of the jig that's hard to do right...you just can't see what's going on at the mill work time.. if you have burn marks in the pocket you are running the bit to fast and staying in the pocket to long..it should go 1,2 and 3 ,your done with that hole..
EZ-Pro Dovetail Jig from General Tools (Part 1 of 2) - YouTube
EZ-Pro Dovetail Jig from General Tools (Part 2 of 2) - YouTube
Amazon.com: General Tools 860 dovetailer EZ Pro dovetail Jig: Home Improvement
http://www.routerforums.com/bargain-...-set-bars.html
post #2 of 13 (permalink) Old 09-27-2011, 09:06 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
You make it look so easy Bob. One of these days I'll dust off one of my dovetail jigs and see if I can make something.
Harry
harrysin is offline
post #3 of 13 (permalink) Old 09-27-2011, 10:13 AM Thread Starter
Hi Harry
It is if you use the right jig and use it the right way.
I have pushed the EZ jig as of late and some have come back and said they could not get a good dovetail joint..= so the How-To-Do-it the easy way.
The video(s) are good but they must stop the video and take a hard look at what they are saying or not saying, he is pushing the jig not how to use it,so to speak.
I have one more trick to showing how to set it up for wide stock but I'm going to hold off it for a bit, it's for putting the pockets in place for wide stock, that they do not show in the video..
Many get the dovetail type jig below and it's one of the hardest one to use and setup, I did post how to rework the jig but it's not easy.
Dovetail Machine
I'm looking forward to seeing your jig and what you come out with.
post #4 of 13 (permalink) Old 09-29-2011, 03:25 PM
Burke's Avatar
First Name: Burke
Thanks for taking the time to do this, Bob. Very nice pictures and informative text. Looks like a great jig to have, and I may look into ordering one. I had looked at the Harbor Freight jig, but was hesitant to get it after seeing the reviews it had.
Burke
Burke is offline
post #5 of 13 (permalink) Old 09-29-2011, 08:17 PM
The original reason for making dovetail joints was to help the glue keep the joint connected. With todays glues that is no longer necessary but they are still pleasing to the eye. I have an old Porter Cable jig that will get a work out one of these days.
post #6 of 13 (permalink) Old 02-03-2013, 11:34 PM
Talking
Come to think of it, I still don't recall seeing any dovetail projects from Harry?
ROTFL......
Sydney, Australia
jw2170 is offline
post #7 of 13 (permalink) Old 02-04-2013, 06:40 AM Thread Starter
Hi James
I think it's a CRS thing for Harry..
ROTFL......
post #8 of 13 (permalink) Old 04-02-2014, 07:43 PM
First Name: Ellery
I just tried my new EZ Pro Dovetail II 861. I watched the videos, read the instructions,
Read the tips, (thanks BJ). I used the guide collar method. I used a dial indicator to center it to the bit. It was off by .030. I used an adjustable parallel to set the bit height, and the depth gauge. Carefully clamped the wood in the jig, and cut my first dovetail.
It was perfect. The key was in the precise set up. Being a machinist I know the importance of a good solid set up. There is a learning curve in any fixture. This one was no different. It performed as it advertised, precise dovetails. Thanks for all of the helpful information in this forum. It makes woodworking enjoyable.
Ellery Becnel
Arcola60 is offline
post #9 of 13 (permalink) Old 01-13-2020, 08:52 AM
hello BJ and don't know if you're still active on this forum...I just purchased the 861 model and need to replace the
bit (too much practicing!).....looks like you've also done the same and wondering what it is that you've stacked on top
of the two bearings and locked bearing supplied with the jig - is it another locked bearing?....if so are you able to provide
size and diameter?
thanks
Steviebee2
steviebee2 is offline
post #10 of 13 (permalink) Old 01-13-2020, 05:24 PM
size and diameter?
thanks
Steviebee2
@steviebee2
Unfortunately, BJ passed away a few years ago....
He was, at the time one of our most prolific and venerated members...
Sydney, Australia
jw2170 is offline
Peachtree 15 inch dovetail jig Noob Jigs and Fixtures 13 12-03-2013 07:37 PM
New Lower Priced Leigh Dovetail Jig scrollwolf Jigs and Fixtures 1 07-08-2007 05:10 PM
