1/2 blind Dovetail Jig - Router Forums
post #1 of 6 (permalink) Old 09-30-2011, 01:58 PM Thread Starter
lenh's Avatar
First Name: Len
Default 1/2 blind Dovetail Jig
I want to cut half blind dovetails in small drawers that have 1/2" fronts and 1/4" sides. the PC 4200 series that I have will only machine material that is a 1/2" thick minimum. Even the mini dovetail template requires material that is 1/2" thick. Is there a jig that will do what I want?
lenh is offline
post #2 of 6 (permalink) Old 09-30-2011, 02:34 PM
Dal300's Avatar
First Name: Dallas
Layer two pieces of 1/4" together.. then you have your 1/2".
Also, you may want to make it even thicker. I have a difficult time making box joints or dovetails in thin stuff without getting a lot of tear out. I usually have to use a backer board.
Dal300 is offline
post #3 of 6 (permalink) Old 09-30-2011, 03:27 PM
Hi Ken
Not for the blind dovetail but the one below will do it easy
The Katie Jig Jr. - Katie Jig Tool System
http://www.sommerfeldtools.com/Organ...ctinfo/SOKJHB/
http://www.sommerfeldtools.com/New-K...ductinfo/SOKJ/
http://www.ebay.com/itm/5pc-Top-Bear...item20bbb1d747
post #4 of 6 (permalink) Old 09-30-2011, 05:37 PM
The standard half-blind template is the only template that requires 1/2" min. It will handle 1/2" - 1-1/8" material. All the other templates handle 1/4" & up.
If you have the miniature template you can do through dovetails in material 1/4" - 1/2" both tails & pins. You can do box joints in 1/4" - 1/2" material. Can you make your sides 1/2" then you can make half-blind dovetails with the template you have? It's only a 1/2" total difference.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #5 of 6 (permalink) Old 09-30-2011, 07:17 PM Thread Starter
lenh's Avatar
First Name: Len
James,
Thanks for the response. i'm making a bunch of little drawers that are only about 4 inches wide by 2 1/4 high. The drawer fronts will be 1/2". I tend to think that 1/2" sides won't look right. Admittedly I won't lose much drawer space, it's aesthetic. i'm beginning to wonder if there is such a jig that will do this. Cutting the pins seems to be the real hangup. My little brain is going in all different directions. I could use 1/4" materal all around and cut through dovetails and then glue on a false front of 1/4" material. Or, looks be damned and just use 1/2" for the sides. Or I could use a lock miter joint or a rebbbeted joint. Since the fronts will be walnut and the sides maple I like the look of dovetails. Strength is not an issue in drawers this size.
lenh is offline
post #6 of 6 (permalink) Old 09-30-2011, 07:30 PM
HI Len
Why not use the router bit below and do it all with one router bit when they are that small it's not a bit deal to see the box joints showing .. and it's quick and easy do all the parts at one time with just a pass or two by the bit then pop in your 1/8" slot cutter to put the slot in place for the bottom and you have them all done with in 5 mins.for ea. drawer and your ready for glue up time.. but I do suggest a little bead cut on the front of the drawers for that pro.look..
1 PC 1/2" SH 5 Slots Adjustable Box Joint Router Bit | eBay
Need Jig for Dovetailing stock + Rockler woes + Katie? JavaGeek Jigs and Fixtures 16 02-17-2011 01:46 PM
New Dovetail Jig for $30 - is it worth it? Gweedz Jigs and Fixtures 6 09-19-2010 08:57 AM
Dovetail Jig - Dakota Ebony Guide Bushings and Templates 2 07-07-2010 07:42 AM
Sliding DoveTail Jig bobj3 Jigs and Fixtures 5 01-06-2007 08:31 PM
DoveTail Jig for the Router Table bobj3 Jigs and Fixtures 32 11-30-2006 04:02 PM
