Variation to Skis - Router Forums
post #1 of 22 (permalink) Old 10-03-2011, 12:03 AM Thread Starter
First Name: Simon
Default Variation to Skis
Hi all,
had a thought about making a set of skis on the weekend and thought I'd make my rails slightly differently.
Rather than have a thread on the outside of the rail, I've tapped a hole into the end of the rail.
I got some 12mm galvanised mild steel bar, grabbed it in my drill press using a 25mm block of mdf with a 12mm hole dilled through it and a compression slot cut through the hole in the MDF.
I then compressed the MDF around the 12mm bar with a vise clamp. This wasn't entirely successful and I then had to put a c clamp below to bolster the grip.
To get the rails long enough I had to turn the head on my drill press and pop a hole through the base.
I drilled a hole in the ends of the rails and then tapped them with a 6mm 1mm pitch tap. I found some stainless button headed cap screws to use and some fender washers to grab the ski.
The I was just about to make the ski's themselves and a transformer blew in our neighbourhood cutting power off!
Oh well now I have a job for next weekend
have attached some pics below
cheers - Simon
ps there are some pics of a quickie circle jig I made. After looking around here though, I think Im going to have to rebuild it with a bit more beauty attached, you guys do some nice stuff!
router01 is offline
post #2 of 22 (permalink) Old 10-03-2011, 12:29 AM
First Name: Alex
Sweet looking jig, Simon! I think I'll CC it :-D
lastberserker is offline
post #3 of 22 (permalink) Old 10-10-2011, 12:53 AM Thread Starter
First Name: Simon
Thanks Alex,
I'm really going to have to re-do that circle jig though after seeing some of the nice projects on here
I saw someone useing that nylon they use in kitchen cutting boards which has sort of taken my fancy, looked very nice, and would slide beautifully.
again, thanks for your kind comment
cheers - Simon
router01 is offline
post #4 of 22 (permalink) Old 10-10-2011, 01:08 AM
Simon, it's not nylon... it's polyurethane.
post #5 of 22 (permalink) Old 10-10-2011, 08:07 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Originally Posted by router01 View Post
Hi all,
cheers - Simon
Whilst I think that you've hit on a good idea in making a female thread, something that most members would be capable of doing, I really don't think this is a SKI jig, as shown it appears to be a jig for routing slots only.
Harry
harrysin is offline
post #6 of 22 (permalink) Old 10-10-2011, 11:28 AM
Harry, if you read the post carefully you will see the photos are a circle jig.
post #7 of 22 (permalink) Old 10-10-2011, 09:51 PM
BigJimAK's Avatar
Mike,
Polyurethane or HD Polyethelene?
BigJimAK is offline
post #8 of 22 (permalink) Old 10-10-2011, 10:14 PM
harrysin's Avatar
First Name: Harry
Michael, the thread is headed "variation to skis" and nowhere in the text could I find a mention of the word "circle"
Harry
harrysin is offline
post #9 of 22 (permalink) Old 10-11-2011, 02:09 AM
Harry:
"ps there are some pics of a quickie circle jig I made. After looking around here though, I think Im going to have to rebuild it with a bit more beauty attached, you guys do some nice stuff!"
Jim, Oops! I believe they are just polyethylene. The HDPE is self lubricating and feels really slick.
post #10 of 22 (permalink) Old 10-11-2011, 02:54 AM
gav
Country: Croatia
First Name: Gavin
A little tip for you Harry. If you are looking for a particular word on a webpage, press control F, and a little window pops up where you can type the word you're looking for and then it will find and highlight that word on the page.
gav is offline
Use of skis to thickness wood? rcp612 Jigs and Fixtures 8 05-22-2010 01:13 PM
Routing with the aid of Skis Tom76 Jigs and Fixtures 2 05-18-2010 05:07 PM
Skis under the magnifying glass allthunbs Show N' Tell 9 12-14-2009 07:26 PM
Skis... some questions.... dan_house Jigs and Fixtures 29 04-17-2009 10:38 AM
how to use skis - other devices? allthunbs General Routing 1 08-15-2008 03:22 PM
