Help please - Router Forums
post #1 of 19 (permalink) Old 10-19-2011, 09:52 PM Thread Starter
First Name: Keith
Default Help please
As i am a bit of a novice i need some help please, can someone point me too some free plans to make a "simple" jig for making tenon and mortise's, my first project requires this joint to be used quite a bit and a jig would be brilliant, unfortuanatly I can't afford the shop bought ones costing several hundreds of 's and to be honest i'm not sure how some companies justify their jig prices, anyway i need a simple jig to cut mortise and tenons, mainly in 3" x 2" timber that isn't to difficult to make and use or maybe someone knows a cheapish one to buy say under 50 ?
thank you
Tazkb is offline
post #2 of 19 (permalink) Old 10-19-2011, 11:24 PM
Keith, We can help you build a simple jig to use with your plunge router. You will need a square, 1" guide bushing and a 1/2 or 3/4" wood chisel. What you will be making is a jig like the one shown in this thread: http://www.routerforums.com/jigs-fix...tml#post243480
What brand/model is your router? Do you have a router table?
post #3 of 19 (permalink) Old 10-20-2011, 09:56 AM Thread Starter
First Name: Keith
Thanks Mike
looking at the jig in the thread i'm not sure how that will cut tenon's ?
the router is a Erbauer 2100w 1/2in job which my wife bought me for my 50th birthday, however she also bought me a 30 piece kit of cutters which are 1/4" not her fault she didn't realise, still i have a 1/4" collet etc so they can still be used, I do have a router table mike but it's still in the box after 2 years I am looking for a cheap router to fix into the router table on a permenant basis. my workshop isn't very big and at the moment is being transformed, with an 8' x 8' extention and some new tools so i can start making some stuff (well thats the idea ) i'm partly disabled as well mike so limited to what i can do, (nothing to physicaly demanding) although normaly turn my hands to most things quite well. If i had the money I would just buy the trend tenon and mortice jig but at 200 + UK I can't justify that kind of money, however I do need to be able to cut tenons and mortices, I did think about a tenon jig for my table saw but the thing about using the router is you can do everything with one tool which appeals to me.
thanks
Keith
Tazkb is offline
post #4 of 19 (permalink) Old 10-20-2011, 12:59 PM
Keith, the jig will handle the job. Your router came with a 30 mm guide bushing and you will build your jig with 30 mm between the bars. With a 1" plunge cutting bit all you will need to do is square up the corners of your mortise with a chisel. Clamping your jig across the work piece will let you make perfectly square cuts on the tenons. I will be building this jig on Saturday and will take a couple photos showing how to use it for your project.
post #5 of 19 (permalink) Old 10-21-2011, 05:24 AM Thread Starter
First Name: Keith
thanks Mike thats very kind of you
much appreciated
Tazkb is offline
post #6 of 19 (permalink) Old 10-29-2011, 08:04 PM Thread Starter
First Name: Keith
sorry iv'e been away for a week on holliday in Scotland
have you had chance to sort the pictures and instructions out yet please Mike ?
thanks
Keith
Tazkb is offline
post #7 of 19 (permalink) Old 10-30-2011, 10:34 AM
derek willis's Avatar
First Name: Derek
Keith,
Look in my downloads, pages 6, 7 + here you will find a simple way to cut the two joints.
Derek
derek willis is offline
post #8 of 19 (permalink) Old 10-30-2011, 05:08 PM Thread Starter
First Name: Keith
ohh ok Derek will do
Tazkb is offline
post #9 of 19 (permalink) Old 10-30-2011, 05:09 PM Thread Starter
First Name: Keith
I am experimenting with various designs for new base plates at the moment
Tazkb is offline
post #10 of 19 (permalink) Old 10-30-2011, 05:11 PM Thread Starter
First Name: Keith
Don't know why they don't make the guide bushing size universal to all routers, mine are 90mm dia ?
Tazkb is offline
