Another Circle cutting Jig - Router Forums
post #1 of 5 (permalink) Old 11-03-2011, 06:01 AM Thread Starter
First Name: Floyd
Default Another Circle cutting Jig
This is an adjustable circle jig I recently made to cut a picture frame for a piece of stained glass I made years ago.
The jig base is made from some imitation hardwood flooring that I found in a dumpster.
Frame pieces were glued up and held together until glue dried then pocket hole screws removed and splines installed. The rabbet on the frame was cut first, than slowly taken down the outside edge.
Another Circle cutting Jig-1.jpg Another Circle cutting Jig-2.jpg Another Circle cutting Jig-3.jpg
Another Circle cutting Jig-4.jpg Another Circle cutting Jig-5.jpg Another Circle cutting Jig-6.jpg
FD_Cox is offline
post #2 of 5 (permalink) Old 11-03-2011, 06:23 AM
Nice job. Splining is one of my favorite joinery methods too.
post #3 of 5 (permalink) Old 11-03-2011, 07:03 PM
Very nice, Floyd.
Can I ask how you inserted the splines after the pieces were glued together?
Sydney, Australia
jw2170 is offline
post #4 of 5 (permalink) Old 11-04-2011, 03:24 AM Thread Starter
First Name: Floyd
Originally Posted by jw2170 View Post
Very nice, Floyd.
James, I made a jig to run against the fence of the table saw to cut the splines, I should have put the actual jig in the post.
Floyd
FD_Cox is offline
post #5 of 5 (permalink) Old 11-04-2011, 08:54 AM
Hi Floyd
Nice job
May I suggest one more way
Using the router table and a Coping Sled and a slot cutters to put the spine slot in place, once the spines are glued in place just use a center block in the center of the frame for the center point and hold the frame down in place with some tape (DST ) just about any cir.jig will do the job easy..
To take the place of the nasty pocket hole screws and the need to deal with holes on the back side of the frame,it's true you don't see them from the front BUT. ▼ why make it harder than it needs to be
Merle Band Clamp with Self Adjusting Jaws
Professional Coping Safety Sled set on the 22 1/2 miter with a slot cutter doing all the work.
MLCS Safety Accessories
Free Floating Circle Cutting Router Jig Santé Jigs and Fixtures 11 09-11-2014 11:12 PM
Building a Circle Cutting Jig darrink Jigs and Fixtures 26 12-05-2011 07:01 AM
circle cutting jig jtomeo Jigs and Fixtures 24 06-30-2010 06:10 PM
