Dovetail jigs - Router Forums
post #1 of 8 (permalink) Old 11-22-2011, 10:44 AM Thread Starter
Cochese's Avatar
First Name: C
Default Dovetail jigs
I know it's not always accurate to just go by looks, but it seems like the Rockler, HF and Peachtree jigs are, if not the same, very close.
I was thinking it might be nice to add templates from the more supported versions to the HF base, if that was possible. Anyone have any insight to this?
The 144 Workshop - Ambitious but rubbish woodworking
Cochese is offline
post #2 of 8 (permalink) Old 11-22-2011, 10:53 AM
HI
Most are made by WoodStock
" add templates " not to sure what you mean the templates they come with them are fine it's the wood stock and the clamping system that has the down fall with them.
I did rework the HF one and now it works right every time, see the rework in my uploads..
post #3 of 8 (permalink) Old 11-22-2011, 11:03 AM Thread Starter
Cochese's Avatar
First Name: C
Different style templates, I should have said.
Last couple of times I went into Rockler they had a few of their templates on clearance.
Cochese is offline
post #4 of 8 (permalink) Old 11-22-2011, 11:08 AM
HI
You can get them also from Grizzly a little lower in the price..
http://www.grizzly.com/search/search...l%20bit&page=3
http://www.grizzly.com/search/search...l%20bit&page=2
post #5 of 8 (permalink) Old 11-22-2011, 11:44 AM Thread Starter
Cochese's Avatar
First Name: C
Thanks Bob. I'll check out your uploads a bit later. I have an idea for easy setup, but want to see what you've come up with first.
Cochese is offline
post #6 of 8 (permalink) Old 11-22-2011, 12:33 PM
HI
Here's a link
http://www.routerforums.com/general-...etail-jig.html
The real key for the HF jig and others is to use a dovetail bit with a bearing on it, in that way the bit is always dead on unlike using the guides that are never dead on with the shank of the bit, just a little bit off and the dovetails will not fit right..that's a little tip that took me 3 years of working with dovetail jigs..
http://www.grizzly.com/products/1-2-...-4-Shank/C1660
http://www.grizzly.com/products/1-2-...4-Shank/C1660Z
post #7 of 8 (permalink) Old 11-22-2011, 02:42 PM
First Name: gary
Where does one find DT bits with a bearing on the shank? It makes sense.
garycurtis is offline
post #8 of 8 (permalink) Old 11-22-2011, 02:54 PM
Hi Gary
See link above but you can add a bearing(s) to any dovetail bit the longer the better..with lock collars..
http://www.ebay.com/itm/16-pc-1-4-Sh...item20bed05507
http://www.mlcswoodworking.com/shops..._guides_anchor
dovetail jigs etc in UK thecoder Jigs and Fixtures 7 05-24-2011 04:01 PM
Dovetail Jigs Compared 12 brands + 1 allthunbs Woodworking Articles 1 03-31-2011 05:44 PM
Dovetail Jigs Marcus Jigs and Fixtures 2 01-05-2010 03:58 PM
dovetail jigs, rocklerbei robbie mc Jigs and Fixtures 1 09-07-2009 04:58 PM
Dovetail Jigs and size limits rjryerson Jigs and Fixtures 16 05-18-2007 05:45 PM
