Making a template - Router Forums
post #1 of 5 (permalink) Old 11-22-2011, 09:35 PM Thread Starter
First Name: Tommy
Default Making a template
I just ordered the rockler mounting plate for the router table I am trying to build. I didn't order the template for it because a lot of reviewers that did, said when they used it, along with the 1/2" pattern cutting bit...sold seperately, the router plate had a 1/16" slack around it. Does that mean you are supposed to use a guide bushing or something, or is the template too big.
I was wondering because I had read some messages on here about offsets and stuff when you use patterns.... there is alot of good advice on the forum by the way..being new to routing and the forum I need all I can get.
Tommy
troutfish is offline
post #2 of 5 (permalink) Old 11-22-2011, 10:00 PM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Tommy
A very easy way is to make a template is by cutting four pieces of MDF such that when glued together will produce the correct size opening and this is calculated by this simple formula: diameter of guide minus diameter of straight bit plus the size of the required opening. For example, if we require an opening 11" x 10.5" and we use a 1" guide with a 1/4" bit, we have the following:
1" -1/4" + 11" = 11 3/4"
1" - 1/4" +10.5" = 11 1/4"
this means that using the above combination of guide/bit, an opening in the template of 11.75" x 11.25" will result in a routed opening measuring 11" x 10.5"
Harry
harrysin is offline
post #3 of 5 (permalink) Old 11-22-2011, 10:26 PM
Hi Tommy
Sounds like it's to big, just make your own template see below.
Tommy
Name:	plate install.jpg
Name:	plate install a.jpg
post #4 of 5 (permalink) Old 11-22-2011, 10:41 PM
Tommy, the Rockler templates are too big. I had that problem with the oversized aluminum plate for my PC7518. It is more like 1/32" on two sides. This can be corrected with some shims. I noticed it didn't make any difference once the 7518 was dropped in the table, it didn't move.
post #5 of 5 (permalink) Old 11-23-2011, 08:17 PM Thread Starter
First Name: Tommy
Thanks for all the quick replies, I really appreciate it. I will let you know how it goes.
tommy
Template Making the handyman Jigs and Fixtures 39 01-31-2011 05:42 AM
Making a female template Enticer Guide Bushings and Templates 4 09-05-2009 05:41 PM
making and accurate template for an oval hand mirror bob oswin Jigs and Fixtures 31 01-20-2009 07:36 PM
Making a template, where did I go wrong? Thom2 Guide Bushings and Templates 10 08-09-2007 07:54 AM
