Mortise and Tennon Jig anyone seen this?? - Router Forums
post #1 of 19 (permalink) Old 11-28-2011, 07:12 AM Thread Starter
TheOakDude's Avatar
First Name: Paul
Default Mortise and Tennon Jig anyone seen this??
Hi everyone,
have been looking at these plans but unsure as there are so many out there.
Wondering if anyone has any experience of these and if so how do you rate them
Woodworking Jigs helps machinery reach their full potential.
any guidance would be appreciated.
thanks
The moving finger writes....and having writ moves on...nor all thy piety nor wit shall lure it back to rub out half a line.
TheOakDude is offline
post #2 of 19 (permalink) Old 11-28-2011, 08:36 AM
First Name: Keith
you have to pay for the plans, there are so many free ones about i would look around
Tazkb is offline
post #3 of 19 (permalink) Old 11-28-2011, 12:13 PM
AxlMyk's Avatar
I was visiting Bobj just yesterday, and looked at his M&T jig. Took a couple pictures. Bob Rosenthal designed it. Quite simple to make and use. I'm sure Bj will be around shortly to advise you.
AxlMyk is offline
post #4 of 19 (permalink) Old 11-28-2011, 12:47 PM
HI
Here's some more shots of the easy to make jig, it's made in the KISS way,no need to buy plans it's free right on the best wood working forum on the NET.
http://www.routerforums.com/jigs-fix...ge-router.html
post #5 of 19 (permalink) Old 11-28-2011, 01:08 PM Thread Starter
TheOakDude's Avatar
First Name: Paul
All looks very complicated......thats why I was after the plans for a simple but effective Jig....Bob what is a centering thingy got to do with Mortice and Tennon jig...not ping pong..just genuinely confussed.
thanks
post #6 of 19 (permalink) Old 11-28-2011, 01:17 PM
Hi Paul
" centering thingy ' = ????
thanks
post #7 of 19 (permalink) Old 11-28-2011, 01:21 PM Thread Starter
TheOakDude's Avatar
First Name: Paul
the links were referring to a centering thingy...seemed like polycarbonate ringy thing??
Any chance of some direct plans for making this??
I believe you are the man for sorting this but I need clear guidance rather than somelinks which seem to outine something differnt to what I need.
The pics do indeed look complicated.....maybe I should leave mortice and tennon for a later date when I am more competent.
post #8 of 19 (permalink) Old 11-28-2011, 01:44 PM
AxlMyk's Avatar
Hi Paul
I believe he means the base plate with centering pins.
AxlMyk is offline
post #9 of 19 (permalink) Old 11-28-2011, 02:06 PM
HI Paul
" I am more competent " = I think that would be best
I did post the plans and I'm sorry you don't get it ,,,it's so simple, it's all base on the Geometry ,,, from point A to C the one in the center (B) the bit ,,will always be dead on center..
This may help you get it
http://www.rockler.com/product.cfm?p...1FE7A43A785DEB
The jig is just a way to hold the stock,the key is the router base plate with pins or bearing..(for floating type Tenons/Loose Tenons) but it can be used also the other way (stud type Tenons) but it takes more of a setup. (like below)
But the one below maybe your bag
http://www.routerforums.com/tools-wo...rtise-pal.html
http://www.mortisepal.com/video.html
http://www.amazon.com/Mortise-Pal-Pr...2531103&sr=1-1
just one more jig at $149.oo
http://www.generaltools.com/870--EZ-...IG_p_1295.html
http://www.youtube.com/watch?v=ivDIVotjO68
http://www.routerforums.com/show-n-t...h-m-t-jig.html
BUT the very best one I have found and use is the one below.
for Loose Tenons, I can use 3/8" to 1 1/2" wide (and wider if needed) stock and no router needed
http://www.youtube.com/watch?v=_VtVGnxlBrc
post #10 of 19 (permalink) Old 11-28-2011, 10:04 PM
AxlMyk's Avatar
Let's try this.
This is a drawing of the base plate which a router is mounted. The bit is at the center, in the hole.
The 2 pins, (or bearings) are against either side of the board that you wish to create a mortise. They are on the same center-line as the bit, and equal distance from center. This puts the bit at the center of the board edge, and when you plunge the bit into the wood and slide the base plate along the edge, you create a mortise. That mortise is centered in the board edge.
The jig Bob and I have posted is nothing more than a way to hold the wood steady, and the bit perpendicular, as you create the mortise.
AxlMyk is offline
has anyone got or used this Jig ? Tazkb Jigs and Fixtures 8 11-27-2011 09:58 AM
mortise & tennon jig jsoika Jigs and Fixtures 9 05-08-2008 12:14 AM
Mortise & Tenon Jig electrovoltz Jigs and Fixtures 6 04-20-2006 01:28 PM
