Clydesdale walking stick - Router Forums
post #1 of 4 (permalink) Old 12-01-2011, 12:30 PM Thread Starter
Gene Howe's Avatar
First Name: Gene
Default Clydesdale walking stick
I found one of these at a yard sale in KY.
It's one side of a fancy horse collar. Think Budweiser Clydesdales.
It will be the top of an inlaid walking stick.
I don't turn, so I'm now in the process of building a simple router jig to turn the stick. Ala Bill Hylton in Router Magic.
When I get the jig built I'll have some pics. Then more as I use it to turn and create cavities for epoxy and turquoise inlays.
We are headed for Okinawa on the 12th of this month, so the build may be prolonged.
Stay tuned.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #2 of 4 (permalink) Old 12-01-2011, 01:58 PM
papawd's Avatar
First Name: warren
Cool , nice find
papawd is offline
post #3 of 4 (permalink) Old 12-10-2011, 02:08 PM Thread Starter
Gene Howe's Avatar
First Name: Gene
Default Router Lathe and Cane
Here's the router lathe box with the router in place.
I used a Bowl Cutter to rout the cane.
This is the crank end.
Here is the dial to locate the cavities for the inlay. The little square block is on the end of a 1/4" dowel through the dial and in to the box end.
Here's the hame and end cap loosely fitted on the walnut cane. Good fit, by golly!
[ATTACH]Clydesdale walking stick-cane1.jpg[/ATTACH]
When we get back, I'll do the inlays.
Gene Howe
Snowflake, AZ
post #4 of 4 (permalink) Old 12-12-2011, 05:58 AM
First Name: Ian
Sweet job Gene.
Looking forward to the inlay pics.
Cheers, Ian
Nanigai is offline
Router crafter/ router lathe candle stick Jack Wilson General Routing 14 12-27-2010 10:01 PM
Push Stick Kje8199058 Tools and Woodworking 4 10-30-2010 10:32 AM
Bad Wood For Stick Method cbsjoez1935 Jigs and Fixtures 4 12-30-2009 06:47 PM
Choosing a Cope & Stick Set Padawan Learner Router Bits - Types and Usage 17 10-20-2009 11:57 PM
Rounding off the ends of a stick tpyke Table-mounted Routing 5 03-03-2008 04:14 PM
