holeless circle cutting - Router Forums
post #1 of 51 (permalink) Old 12-03-2011, 08:28 AM Thread Starter
First Name: Pauli
Default holeless circle cutting
Hi all,
I want ot cut a 3-1/2" diameter disk out of 3/4"walnut without leaving a pivot point hole. Do you have any sugestions? I have a router table.
Pauli
pauli mac is offline
post #2 of 51 (permalink) Old 12-03-2011, 09:14 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Originally Posted by pauli mac View Post
Hi all,
Pauli
This is the way that I generally accomplish this task. To calculate the size of hole in the template: template guide dia. minus bit dia. plus the size of the disc you require.
For example, using a 1" guide and a 1/4" bit, we have: 1" - 1/4" + 3 1/2" = 4 1/4" hole in the template.
Name:	2nd coin tray8.jpg
Name:	small box11.jpg
Harry
harrysin is offline
post #3 of 51 (permalink) Old 12-03-2011, 10:00 AM
Hi Pauli
Just one more way, a hole saw will do the trick easy, just use it without the drill bit in the center of the hole saw..most of the hole saws(the better ones) have a way to replace the drill bit with a new one, just don't put it back in place and use in on the drill press..
http://www.amazon.com/DEWALT-DW1803-...2928936&sr=1-9
One more way that works great also.
Trend Pivot Frame Jig - YouTube
You can order the jig from Amazon or make one easy like I did..
see it in my uploads
Just a note
Yes that's a 40mm guide you see in the snapshot that Harry made for me..
post #4 of 51 (permalink) Old 12-03-2011, 12:06 PM
Mike Wingate's Avatar
First Name: mike
Drill a hole in a scrap piece of wood or plastic smaller than the disc size you want. Tape or hot glue the piece of wood or plastic to the piece of wood you need the disc from. Use your router with chosen jig. Cut disc. Separate scrap from disc. Photo of my current jig.
Mike Wingate is offline
post #5 of 51 (permalink) Old 12-03-2011, 02:50 PM
Santé's Avatar
Country: Belgium
First Name: Daniel
Hi all,
I use this jig : http://www.lescopeaux.asso.fr/Techni...de_Anglais.pdf
This PDF file is in english
Santé
Member of the french site for woodworkers
Santé is offline
post #6 of 51 (permalink) Old 12-03-2011, 03:33 PM
First Name: mike
Really nice jig Santé.
post #7 of 51 (permalink) Old 12-05-2011, 11:32 AM
One of the options would be to make a template with an equation:
Template diameter=Hole diameter+Guide diameter-Bit diameter
For example:
Diameter of the hole I wan't to make:40mm
My guide diameter:30mm
Bit diameret:8mm
And the diameter of the template is:40+30-8=62mm
Regards
giltic is offline
post #8 of 51 (permalink) Old 12-05-2011, 11:47 AM
Hi giltic
That's a great way but in the states we can't get a 40mm guide the norm and how did you make the template ...that must be dead on,,
For example:
Bit diameret:8mm
Regards
post #9 of 51 (permalink) Old 12-06-2011, 12:13 PM
bobj3;
It was just an example. You can use whatever template and bit you have and calculate the hole with the equation I've wrote.
The template was made with ordinary hole cutting jig - the one you have to drill a hole for centering pin.
Harrysin gave the same example in inches.
giltic is offline
post #10 of 51 (permalink) Old 12-06-2011, 01:03 PM
Hi giltic
No center pin needed, no hole needed at all or template other than the jig and it will cut the hole out for the jig to run on the inside or out side . cir. cut out from 1/4" in diam to ~, one jig for MANY jobs.
http://www.youtube.com/watch?v=18CUKZo2JUE
bobj3;
Cutting out Circles and Arcs the Easy Way learnexperience Portable Routing 1 11-26-2011 01:29 PM
Cutting a Circle rjg202 Tools and Woodworking 15 11-12-2011 08:44 AM
cutting small circle with circle centre outside toadhall Jigs and Fixtures 12 12-06-2009 01:46 AM
