MLCS Circle Jig - Router Forums
post #1 of 8 (permalink) Old 12-07-2011, 08:04 PM Thread Starter
First Name: Larry
Default MLCS Circle Jig
Anybody have any comments or experience on the new MLCS circle jig?
I haven't been too active so I'm unable to post urls.
larryc is offline
post #2 of 8 (permalink) Old 12-08-2011, 04:47 AM
Gene Howe's Avatar
First Name: Gene
Don't have one because there's no T Track in my table. But, it looks like it works just like the router mounted types. They work just fine. So, the MLCS jig should be just fine, too.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #3 of 8 (permalink) Old 12-08-2011, 07:15 PM Thread Starter
First Name: Larry
Well I just became legal so here is the url for new MLCS Circle jig:
NEW ITEM in Stock! Router Circle Jig (with Bonus Bit!)
larryc is offline
post #4 of 8 (permalink) Old 12-08-2011, 07:27 PM
Hi Larry
I don't have one but I made my own. ..
see the links below. For John's N. ( Eagle Lake ) web site
post #5 of 8 (permalink) Old 12-08-2011, 07:34 PM
Hi Gene
You don't need a tee track to cut cir. on the router table
post #6 of 8 (permalink) Old 12-08-2011, 07:44 PM Thread Starter
First Name: Larry
Hi Larry
That's great if you have a motorized lift with a foot switch since both hands are otherwise occupied.
I have a crank lift and I am wondering if the MLCS circle jig will work with the crank lift.
larryc is offline
post #7 of 8 (permalink) Old 12-08-2011, 07:47 PM Thread Starter
First Name: Larry
Hi Gene
Bob
Do you have plans (more info) on that jig?
Looks intriguing.
larryc is offline
post #8 of 8 (permalink) Old 12-08-2011, 08:07 PM
Hi Larry
No I don't sorry, but it's a very simple jig to make, just some 3/4" thick MDF with a tee slot down the center for a normal tee slot alum.block to hold a set screw and a bolt for the pivot point, I used some metal banding stock under the Alum.block to keep the set screw from putting in little holes in the MDF stock..
It will cut from a 1 1/2" hole to ~ as long as the board is..
It locks in place place with brass guide at one end of the jig and two screws about about center the board...the new pictures show a hole for the crank lift I use but they don't show in the old pictures below..that's makes is easy to lift the bit right in to the board...
Note the hole for the hand crank, see below, it must be out of the path of the router bit,to the left works for me
Bob
Looks intriguing.
Cutting out Circles and Arcs the Easy Way learnexperience Portable Routing 1 11-26-2011 01:29 PM
Building A High Quality Circle Jig AzViper Jigs and Fixtures 52 06-10-2011 07:59 PM
