Round tenon jig? - Router Forums
post #1 of 10 (permalink) Old 12-08-2011, 09:49 AM Thread Starter
Default Round tenon jig?
Anyone ever build a round tenon jig to put tenons on the ends of rough logs, like the rails of a stockade fence or primative log furniture. I know commercial jigs exist for this purpose, but they're very pricey. Any thoughts, ideas, or drawings would be appreciated.
starsailor is offline
post #2 of 10 (permalink) Old 12-08-2011, 10:21 AM
Hi
I don't have one BUT stop by one of the Fence company's in your town and see what they use, they make them all the time, most use a small chain saw jig on a side grinder type tool I'm sure you know you can get the tools at Rockler just for that type of job..from the small to the big ones.
post #3 of 10 (permalink) Old 12-08-2011, 10:26 AM
Bob Rosendahl, a true master of jig design developed a round tenon cutting jig. While this is used for table legs the same design would work for your purposes. No plans are available for this but it can be viewed in episode 1307 of the Router Workshop TV show. The show is no longer on TV and is available only through Routerworkshop.net You might go there and post a message for Rick Rosendahl asking for help on this. These images are from that episode.
Name:	Round tenon jig1.JPG
Name:	Round tenon jig2.JPG
post #4 of 10 (permalink) Old 12-08-2011, 11:06 AM
Hi Mike
I made that jig, it's great for small ones but not practical for the big ones..but than I didn't try and make big ones, the jig is a bit of a tank just for the small ones..
But I use the bearing way so to say a round wood disk would work for the big ones.I guess..
post #5 of 10 (permalink) Old 12-08-2011, 01:31 PM
Santé's Avatar
Country: Belgium
First Name: Daniel
Hi Starsailor,
Look at this video.
Festool - Runde Zapfen anfräsen - YouTube
More details at this address with plan and measures
http://www.lescopeaux.asso.fr/Techni...nons_Ronds.pdf
Member of the french site for woodworkers
Santé is offline
post #6 of 10 (permalink) Old 12-08-2011, 02:08 PM
Tenon Cutters
MLCS Tenon Cutter Set and Plug Cutter Set
They work quick and easy on any drill press or with most hand drills...
Or use it/them for making the jig below
Not to sure if I would try that in that video looks little bit to hairy, dropping a floating stick on a turning bit WOW, hang on it's going to be bumpy ride I think... not to saying anything about the load on the cutters and when it locks up the stock and snaps off the cutters WOW..hang on baby or snaps the bit right off WOW..or just bends the bit over WOW...
Name:	T cutters.jpg
post #7 of 10 (permalink) Old 12-08-2011, 03:57 PM
Originally Posted by Santé View Post
Hi Starsailor,
Look at this video.
Thanks, Daniel,
Very informative, even without the translation.
Sydney, Australia
jw2170 is offline
post #8 of 10 (permalink) Old 12-09-2011, 03:14 AM
gav
Country: Croatia
First Name: Gavin
Tenon Cutters
That's a lot of Wows Bob. Do you mind explaining exactly what your concerns are ?
I watched the video and there is no 'floating stick', everything is held firmly and there is no untoward movement of the stock at all during the routing process. It looks to be a very safe and secure way of getting the job done.
gav is offline
post #9 of 10 (permalink) Old 12-09-2011, 07:57 AM
Gavin, I think the point that BJ is trying to make is most people use carbide bits and while they stay sharp much longer than HSS they are also brittle and sensitive to impact. Just starting a router with a carbide tipped cutter in contact with a fence is a recipe for disaster; the carbide will peel off the bit and go sailing. My guess is the video used HSS bits which can withstand impacts better but dull much faster. Interesting designs but I would not recommend that a beginning router user tried them.
post #10 of 10 (permalink) Old 12-09-2011, 09:07 AM
Hi gav
Well I have a jig that's like that almost and it's very hairy to use, so to say been there done that, the 'floating stick' the key word is "held by hand" and yes the stick must move in and on top of the cutter and if your grip slips look out..it's TP time..
And yes I have used it to put on Round tenons on sticks the errors comes from no real way to stop the stick from stopping ,the bit wants to suck the stick down into the hole and than it's jam time or break the bit right off..(1/4" shank or 1/2" shank" at 10,000 to 15,000 rpm's things happen real quick..
The jig below is used for putting on a nice clean chamfer or round over on the ends of dowels the norm.
Gavs Box/mortise and tenon jig gav Jigs and Fixtures 21 11-08-2009 04:10 PM
mortise & tenon jig yairfe Jigs and Fixtures 23 10-21-2009 05:49 PM
