oval & circle cutting jigs - Router Forums
post #1 of 4 (permalink) Old 12-22-2011, 12:54 PM Thread Starter
First Name: frosty
Question oval & circle cutting jigs
I am looking for a good source to copy/use for making circle and oval jigs for my shop. Am presenting using just a plywood trammel for the circles, but would like something more pemanent and substanial, so I don't have to remake them after a few uses. Don't have an oval or elipse jig, but have a couple of small projects i want to do using it.
Any advice/help is greatly appreciated.
frostdude
frosty50 is offline
post #2 of 4 (permalink) Old 12-22-2011, 01:15 PM
HI frosty
The key is the size, most oval jigs can't do any thing smaller than 8 1/2" that's when the pastic template come to play, one 10" oval template out of plastic and some OffSet rings and you can make them down to 3" easy..all with one template.
You can use a Oval picture FRAME for your 1st.template setup..
http://www.routerforums.com/tools-wo...ure-frame.html
frostdude
post #3 of 4 (permalink) Old 12-22-2011, 01:25 PM Thread Starter
First Name: frosty
I am looking at making a large oval mirror for the wife that is attached to a stand, probably 22-24" by 42-48". I want it to be symeterical, that is why I am looking for a jig to make.
I have used small picture frames as templates, and they work fine for 1 or 2 applications.
frosty50 is offline
post #4 of 4 (permalink) Old 12-22-2011, 01:41 PM
Hi
Check out the
http://www.woodworkingchannel.com/do...eo_library.php
Look at the video by RWS Bob and Rick they will show you how to make a great one and it will be symeterical type the only way ,I don't know how to do any other way..all other oval jigs CAN'T do it right that I know about..
Use this type of jig (see below in the link) once you have the inside or the outside of the mirror cut out..then you set and lock the bearings in place and the jig will follow the contour of the oval, dead on every time..just plunge down with your router and cut out the oval plus it's great way to put in flutes in your mirror frame..to add that nice clean cut to the frame...
http://www.routerforums.com/260972-post6.html
http://www.routerforums.com/260985-post9.html
normal oval jig below
http://www.rockler.com/product.cfm?p...ter=oval%20jig
Cutting out Circles and Arcs the Easy Way learnexperience Portable Routing 1 11-26-2011 01:29 PM
Cutting a Circle rjg202 Tools and Woodworking 15 11-12-2011 08:44 AM
cutting small circle with circle centre outside toadhall Jigs and Fixtures 12 12-06-2009 01:46 AM
Cutting Oval Shapes Potent Jigs and Fixtures 9 10-12-2009 07:27 PM
Drawing ovals AxlMyk Project Plans and How To 46 04-20-2009 07:36 AM
