How Do I Make Rockers? - Router Forums
post #1 of 8 (permalink) Old 12-26-2011, 10:39 AM Thread Starter
steve1123's Avatar
First Name: Steve
Default How Do I Make Rockers?
I need to repair a rocking chair. The "rockers" are broken.
I think they are usually made on a band saw, but I don't have one.
Do you think I could make them with a router and circle jig?
How do I make a circle jig with a 42" radius?
Thanks for your help!!
steve1123 is offline
post #2 of 8 (permalink) Old 12-26-2011, 06:05 PM
Welcome
post #3 of 8 (permalink) Old 12-26-2011, 09:56 PM
CharleyL's Avatar
First Name: Charley
You could use your table saw to cut many thin strips (about 1/8 inch) and make a fixture so you could glue them back together bent around the fixture to form the correct rocker shape. Making them this way would provide a stronger rocker than one that was cut from a straight board using a band saw because the grain would follow the shape of the rocker. Since this is a router forum I'll add that you can use a router to round over the edges and clean up the shape of the rockers once they are glued up.
Charley
CharleyL is offline
post #4 of 8 (permalink) Old 12-27-2011, 12:13 AM
If you aren't using a material thicker than a pattern tracing router bit is long you can cut the new ones close to size and finish them with the router. If you can piece one of the old rockers back together you could use it for a template.
post #5 of 8 (permalink) Old 12-27-2011, 02:13 AM
Hi Steve
You can always use 1/8" or 3/16" thick, good plywood plus glue and use blocks to bend the plywood into the shape you need, the grain of the wood is a big deal for the rocker part..
"How do I make a circle jig with a 42" radius?"
Not a big deal if you want to use your router , pull out a board/plywood mount your router at one end of it and drill a hole at the other end, pull your tape out and from the edge of the bit (at 21" ) drill a hole for a pivot point.
post #6 of 8 (permalink) Old 01-03-2012, 07:38 AM Thread Starter
steve1123's Avatar
First Name: Steve
Thanks a ton everybody! It is cool to get so many great ideas! It makes me think of other projects I could do.
post #7 of 8 (permalink) Old 01-03-2012, 08:24 AM
argoknot's Avatar
First Name: john
Have you thought of using a jig saw? They do a fair job.
Today is the first day of the rest of your life. Live it to it's fullest.
Making sawdust by the sea in Massachusetts
argoknot is offline
post #8 of 8 (permalink) Old 01-05-2012, 07:46 PM
First Name: Andy
As Charley said take a hardwood board and slice it into thin strips 3 to 6 mil the required width and a little longer than required and sand smooth Make a jug or use old runner to make the required curve .Use a good wood glue bend the peices to fit the jig then clamp them so they follow the required line. Most rockers have a flat spot at the ends so they won't let you fall backwards . Have helped neighbour make rockers for rocking horses that stand 42 inches at saddle these are 60 inches long
Andy
andy's Den is offline
Learning How to Make a Tissue Box Cover learnexperience General Routing 2 12-05-2011 05:56 PM
How to Make a Picture Frame learnexperience Table-mounted Routing 10 09-24-2011 04:48 AM
How to Make a Decorative Inlay learnexperience General Routing 1 09-14-2011 08:34 AM
How to Make Wheels learnexperience General Routing 7 09-08-2011 09:27 AM
How to Make a Raised Panel Door learnexperience General Routing 2 09-06-2011 08:39 PM
