Making Mortises in the Face of a Board - Router Forums
post #1 of 19 (permalink) Old 01-03-2012, 08:47 PM Thread Starter
First Name: Justin
Default Making Mortises in the Face of a Board
Hi All,
I am new to this forum, but I am hoping you can give me some pointers on how to setup and make a bunch of various shaped mortises for a children's front-facing rack bookshelf I am working on.
I have attached a couple of sketches for reference. I am most concerned with how to get both sides to match so I can actually assemble it (particularly the ones that are on an angle).
I have already made a basic jig to cut a mortise for a single one of the rounded rails, but I don't have a good way to make sure the other side is at the same angle and positioning.
Any tips would be greatly appreciated since I haven't done anything like this before.
Thanks!
Justin
File Type: pdf Children's Bookshelf - Left Side Dimensions.pdf (70.1 KB, 82 views)
Jmpreiks is offline
post #2 of 19 (permalink) Old 01-03-2012, 11:45 PM
Originally Posted by Jmpreiks View Post
Hi All,
Thanks!
Justin
Hi Justin - Welcome to the forum
I hope you have more pictures than that to work with, there seems to be some significant measurements missing from what I could see.
The approach I would make would be to make templates That would reference the top and backs of the sides. One template could cover the two oval and the inverted "L", another could cover the things on the base. Maybe make a couple of story sticks to make sure they get to the same spot on both sides.
John Schaben
jschaben is offline
post #3 of 19 (permalink) Old 01-04-2012, 12:44 AM
rwl7532's Avatar
First Name: Ralph
OK, I've never done a mortise and this is only my opinion.
The bookcase presented looks like just a few books or magazines would be in the shelves. Why not just doweling to connect the rails to the sides and glue?
If the structure was for climbing, then I would understand the need for mortises.
These are through mortises? If so, clamp the sides together and do each mortise all the way through both pieces at once.
rwl7532 is offline
post #4 of 19 (permalink) Old 01-04-2012, 04:24 AM
Hi Justin,
Welcome to the forum.
Based on the sketches, I would agree with John. A template will make for a more consistent measurements to both sides of the book case
Sydney, Australia
jw2170 is offline
post #5 of 19 (permalink) Old 01-04-2012, 06:55 AM
LexB's Avatar
First Name: Lex
I would make a full-size template from MDF, and use it for both plunging the mortises (using a straight or spiral bit with a guide bushing), and shaping the curved fronts (using a flush-trim bit). To size the mortises on the template correctly, they need to be slightly larger than the straight bit that you'll plunge the mortises with (exactly the difference in diameter between the guide bushing and the straight bit). For example, if you are using a 1/2-inch straight bit and a 5/8-inch guide bushing, then the mortise in the MDF template needs to be 1/8-inch larger than the desired mortise in the workpiece. If you take care making the template, then you'll just flip it when you do the other side piece and you'll have a perfect mirror image.
LexB is offline
post #6 of 19 (permalink) Old 01-04-2012, 07:51 AM
Festool's Domino would be perfect for this application.
waho6o9 is offline
post #7 of 19 (permalink) Old 01-04-2012, 09:58 AM
Justin, a full sized template is the easiest way to go. I would use 1/4" Masonite or Baltic birch plywood. You make your layout once and then fasten it to one side and make your cuts. Flip the template, fasten it to the other side and make those cuts. You will want the template to extend past the end of the wood by at least an inch. This is so you can easily get on and off the template leaving nice clean cuts on the wood. I have built many magazine racks in different styles for a couple magazine distribution companies. I suggest that you build at least 4 of these racks. It never fails when people see them they want one. Save and label your template with the guide bushing sizes and bits used. Odds are you will be building more.
post #8 of 19 (permalink) Old 01-04-2012, 02:03 PM Thread Starter
First Name: Justin
Thanks for all of the advice and suggestions! I was going to take your advice and make a template and started shopping around for guide bushings, but was disappointed to find that the base plate on my Ryobi RE180PL does not accept bushings. I found that Leigh makes an adapter, but read in other threads here the base plate is often not centered and has no way to adjust it other than mounting a secondary base plate onto the factory one...
Instead of going through all of this trouble (+ time and $$$), I think I am going to try to make due with what I've got and use a combination of an angled piece of scrap wood, squares, and straight edges to try to make it as repeatable as possible. I've also thought about buying a mortising bit with a top bearing on it and try that with a template, but I don't know if I can find one locally and don't want to wait for shipping...
I will eventually take care of the base plate situation though, I'd like to be able to do precision routing!
And if you are wondering why I using mortises instead of dowels and/or screws, I have two reasons: 1) I wanted to learn something new on a project that is inexpensive and not too important; 2) It will probably become a ladder to children one day and I'd like for it not to break!
Thanks guys!
Justin
Jmpreiks is offline
post #9 of 19 (permalink) Old 01-04-2012, 02:09 PM
Justin, making your own sub base plate is easy.
Watch the video under the Member Vidoes tab at the top of our home page. There is a link to the sticky thread with discussion about this on the video page.
post #10 of 19 (permalink) Old 01-04-2012, 03:11 PM Thread Starter
First Name: Justin
Thanks Mike. That seems fairly straightforward, I'll do that in the near future. What material due you recommend for the sub base?
Jmpreiks is offline
Face Lift for the Router Fence bobj3 Jigs and Fixtures 8 04-07-2013 09:21 AM
Cutting a slot in the middle of a board Zurt Table-mounted Routing 11 01-11-2011 09:46 AM
cribbage board peg storage space toddfarm New Member Introductions 2 12-19-2010 08:20 PM
Bench hook/Shooting board TwoSkies57 Show N' Tell 5 09-13-2010 06:43 PM
template making wood reds_21 Tools and Woodworking 3 07-10-2005 08:45 AM
