Skis for a Dewalt 611 Router - Router Forums
 3Likes
post #1 of 19 (permalink) Old 01-09-2012, 01:30 PM Thread Starter
First Name: Keith
Default Skis for a Dewalt 611 Router
Hello all,
This is my first post (other than intro) to the forum. I am amazed at the info available on this site. I am just starting to use my router for woodworking projects. I cannot believe the versatility of the tool.
My question "Has anybody made a set of skis for the Dewalt 611 Compact Router?" If so, what size rod would you use?
Thanks in advance for any help.
Keith
BigCountry is offline
post #2 of 19 (permalink) Old 01-09-2012, 01:37 PM
HI Keith
Yes ,I used 5/16" rods. I have 3 sets from 18" to 36" long rods.
Trend Pivot Frame Jig - YouTube
Originally Posted by BigCountry View Post
Hello all,
Keith
Straightlines likes this.
post #3 of 19 (permalink) Old 01-10-2012, 07:16 AM Thread Starter
First Name: Keith
That is awesome!!!!!!!!!!!!! At first I was going to ask how it worked, but I noticed the YouTube link above th pictures and answered my own question. Truly amazing.
I am assuming the material is UHMW plastic?
post #4 of 19 (permalink) Old 01-10-2012, 07:30 AM
Hi Keith
That's true it's UHMW but it can be anything you have to make the beams bars out of I had some scrap of the UHMW that's why I used it..the UHMW is great stuff it will hold the threaded items just like locking type fasteners so to speak.
Plastic will do about the same as UHMW but it's hard to find blocks of it the norm.
Hard wood will work also once you tap the holes they not real clean and have little fibers holding the threaded items in place..
Just a note I used pop bottle caps for the knobs,waste not want knot thing..just some fiber glass resin and a tee nut and you have a very low cost knob.
You can just buy one ,but I'm cheap
http://www.amazon.com/Trend-PFJ-SET-...6202896&sr=1-1
Hope this helps
post #5 of 19 (permalink) Old 01-10-2012, 07:51 AM Thread Starter
First Name: Keith
Do you remember the dimensions of the bar stock you used? Also, do you tap the holes in the UHMW to accept the bolts?
Thanks for your help........
Keith
post #6 of 19 (permalink) Old 01-10-2012, 07:57 AM
Hi Keith
It's 3/4" thick x 1 1/8" wide and 10 1/2" long, but it can be anything you want it to be, I did tap the holes in the UHMW and drilled the holes out a little bit over 5/16" for the rods..they need to slide free so to speak,
The wheels are also UHMW, that stuff is real slick and will not mark up your work bench or router table top .
I used the drill bits below (tenon cutter) and a hole saw to make the wheels..
MLCS Tenon Cutter Set and Plug Cutter Set
UHMW stock from
UHMW Plastic Sheets and Strips
Here's a copy of the Trend jig manual (see below) it helps with making one and how to use it..and some of the other things it can do..just a great fixture/jig i.e Pattern/router working...
Keith
post #7 of 19 (permalink) Old 01-10-2012, 08:14 PM Thread Starter
First Name: Keith
Thank you for all the input. I will need to research and gather some materials. Then, it is time to start building. I am sure it will be a fun little project.
Thanks again,
Keith
post #8 of 19 (permalink) Old 01-10-2012, 08:22 PM
Hi Keith
You're Welcome anytime
Thanks again,
Keith
post #9 of 19 (permalink) Old 08-05-2014, 09:07 AM
Dejure's Avatar
First Name: Kelly
I like this design. First, it should work fine. Second, it just looks "official."
Some 1/4" aluminum plate could be used in place of the nuts under the red knobs. For example, if the knobs are 1-1/2" in diameter, cut knobs from the aluminum stock that are 2-1/2" to 3" in diameter.
The large aluminum lock knobs would make height adjustments significantly faster and easier.
The reason I have what you want is, I never lent it out before.
Scraps are a myth.
Dejure is offline
post #10 of 19 (permalink) Old 05-27-2015, 06:35 PM
Straightlines's Avatar
First Name: Bradley
Bob, thanks for posting such an awesome build!
-- Bradley
Straightlines is online now
Intro and question john spies New Member Introductions 20 12-08-2018 11:08 AM
dewalt 625e router in the grove General Routing 5 10-23-2009 12:10 AM
