Martin's Box Joint Templates???? - Router Forums
post #1 of 5 (permalink) Old 01-27-2012, 12:38 PM Thread Starter
Default Martin's Box Joint Templates????
I wonder if anyone has tried these. I am looking for a foolproof way to make box joints.
I used to use the traditional step sled method and might have to get back to that.
Tollerrouter is offline
post #2 of 5 (permalink) Old 01-27-2012, 12:43 PM Thread Starter
I forgot to put a link to the template; sorry.
routertemplate.net/special_Box_Joint_Jig.htxx
Is there some way I could have edited the first post instead of adding a reply?
I had to fudge the link, since I am not allowed to post one, but changing the XX to ml will fix it.
post #3 of 5 (permalink) Old 01-27-2012, 01:03 PM
The easiest way to make box joints is with the Oak Park Box joint jigs. They are available in three sizes: 1/4, 3/8 and 1/2". Oak Park is no longer in production so when they are gone they are gone. Oak Park Enterprises Ltd.: Catalogue
Just checked and the 1/2" are gone.
post #4 of 5 (permalink) Old 02-20-2012, 03:53 PM
CyberDude's Avatar
First Name: Denny
Default Martin's Box Joint Jig
I've used this jig several dozen times and I find it easy to use with flawless results every time. Once you've created the assembly with your own 2x4's and 1x4's, the rest is simple as pie. It is my first go-to jig when I want a strong joint with lots of glue surface.
CyberDude is offline
post #5 of 5 (permalink) Old 02-20-2012, 04:19 PM
Hi
Just some links to your jig
Router Template | Woodworking Templates | Router Guides
http://www.routertemplate.net/images...structions.pdf
Box Joint Bit bobj3 Router Bits - Types and Usage 18 05-26-2020 08:22 AM
How To Make a Box with a Box Joint learnexperience General Routing 7 08-07-2011 07:07 AM
Box joint jig update horn man Jigs and Fixtures 9 01-07-2010 10:19 PM
Box joint - first attempt Dennis Davis Show N' Tell 5 02-09-2008 09:01 PM
My first finger joint box simplenik Table-mounted Routing 6 06-24-2007 08:52 AM
