Rabbited half blind dovetails on an Incra Jig - Router Forums
post #1 of 7 (permalink) Old 01-28-2012, 05:33 PM Thread Starter
First Name: Hugh
Default Rabbited half blind dovetails on an Incra Jig
I arrived here through the above inquiry . One brief remark regarding a solution was too brief. I need some more explicit instruction being a bit ability "challenged", as it were.
Any one know of a source if indeed it is possible to cut the half-blind rabbited dovetail on the Incra Jig?
Hughbear is offline
post #2 of 7 (permalink) Old 01-28-2012, 08:44 PM
xplorx4's Avatar
First Name: Jerry
Greetings and welcome to the Router Forums. We are glad you have chosen to join us.
Lamentations 3:22-23
xplorx4 is offline
post #3 of 7 (permalink) Old 01-29-2012, 12:14 AM
wbh1963's Avatar
Hello Hugh,
Welcome to the Router Forums!
wbh1963 is flowing with the grain in Arlington, Washington, USA
A day without curls is like a day without sunshine!
wbh1963 is offline
post #4 of 7 (permalink) Old 01-29-2012, 02:53 AM
G'day
Welcome to the router forum.
Thank you for joining us, Hugh.
Sydney, Australia
jw2170 is offline
post #5 of 7 (permalink) Old 01-29-2012, 04:06 AM
gav
Country: Croatia
First Name: Gavin
You might find it easier to just do a normal half blind dovetail and then fake the rabbet by applying a false front on the drawer.
I have no experience with the incra jig though.
gav is offline
post #6 of 7 (permalink) Old 01-29-2012, 04:43 AM
Hi Hugh
Yes it's possible to cut the half-blind rabbited dovetails on the Incra Jig but it's one of the things you must read about or see it done on a DVD/Book it's a little bit tricky so I would suggest you get the book or the DVD b/4 you try on your Incra jig..
This may not be right but it works for me, I put the rabbit in place, 1st. all the way around the front part then I use the bottom of the rabbit cut as a new edge on the board but not forgetting I need to use the 1/2" or ? off set of the new edge,just a smaller box you could say..
Hope this helps
Amazon.com: INCRA LS Positioner Instructional DVD: Home Improvement
Amazon.com: INCRA IJPT1 Projects and Techniques Book: Home Improvement
I should also say I'm not a big fan of the blind dovetail way I like to use the through dovetail way, no math needed just screw the front to the box to get all the fronts to match and I use the Katie jig, you can make a drawer in about 5 mins or less (right out of the shipping box) and they always fit the drawer hole.. I don't like to mill all the stock down to one thickness like that's needed with the blind dovetails with the Katie jig it can be any size you have on hand and all the parts will fit right up at glue up time .
post #7 of 7 (permalink) Old 01-29-2012, 04:55 PM
dutchman 46's Avatar
First Name: Howard
The book can be downloaded, so You have it! But, Paper is better!
John 3:16
dutchman 46 is offline
Incra Jig Process Imporovement tprofera Jigs and Fixtures 21 09-18-2012 08:45 PM
Incra jig and rabbeted half blind dovetails S Bolton Jigs and Fixtures 10 08-24-2007 01:06 PM
