Bosch Router & Template Guides - Router Forums
post #1 of 4 (permalink) Old 02-02-2012, 03:35 PM Thread Starter
First Name: Chris
Default Bosch Router & Template Guides
Hi all. I'm new to the fine carpentry side but have been into rough framing for 15 years on and off. I have been purchasing alot of woodworking tools as of late looking to work my way up to building some kitchen cabinets. I just stumbled onto the site today and I have found alot of good tips already.
I recently purchased a Bosch 1617 Router and a Porter Cable Dovetail Jig 4212(still waiting for delivery). What adapters will I need to use these two together? I purchased the Rigid Kit for 21.00 at HD the other day but not sure if that will work for the two or if there is a better option like the Bosch Template guide kit. I'd like to get which ever will help me center the guides the best. What are the opinions of you guys/gals that use this setup?
Thanks for the great site. There seems to be alot of good info on here.
Chris
CWBowen is offline
post #2 of 4 (permalink) Old 03-13-2012, 08:35 PM
First Name: cole
I bought the same router , there is a adapter that mounts to the bottom of the router to screw porter cable style bushings into . Does not come with the router go figure. otherwise you need to buy bosch bushings .
cole andrews is offline
post #3 of 4 (permalink) Old 04-09-2012, 11:12 PM
First Name: Michael
also Bosch makes a plate for PC style bushings and the Bosch router will also except PC plates without modification.
mveach is offline
post #4 of 4 (permalink) Old 04-10-2012, 12:07 AM
To use guide bushings with a 1617 you need the RA1126 quick release and if you want to use brass PC style bushings and hole reducers you need the RA 1100 adapter. I highly recommend the RA1173AT dust collection accessories and the VAC005 hose.
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
template guides for Bosch Colt RuggerJoe Guide Bushings and Templates 13 02-10-2009 08:41 AM
Bosch Template Guides RustyW Guide Bushings and Templates 4 10-25-2008 02:51 PM
