Where Can I get These Jig Wing Nuts? - Router Forums
post #1 of 23 (permalink) Old 02-08-2012, 02:34 PM Thread Starter
Gaia's Avatar
First Name: Peter
Default Where Can I get These Jig Wing Nuts?
Hi,
I'm in the UK. See the attached tenon jig photo I've tried to find those big black wing nuts, can't find them or anything like them. Any idea where I can source in the UK. If can't get in UK will have to think abroad, any ideas?
Cheers.
Name:	Router Forum.jpg
Gaia is offline
post #2 of 23 (permalink) Old 02-08-2012, 03:01 PM
First Name: Kerry
2bigfeet is offline
post #3 of 23 (permalink) Old 02-08-2012, 04:01 PM Thread Starter
Gaia's Avatar
First Name: Peter
Originally Posted by 2bigfeet View Post
OK thanks.
Gaia is offline
post #4 of 23 (permalink) Old 02-08-2012, 04:41 PM
kp91's Avatar
First Name: Doug
Peter,
You can make them as well using t-nuts and scrap blocks. Bobj3 has a tutorial or two on how to make your own wood knobs.
I've used brass and aluminum ends and tapped out the right sized hole as well.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #5 of 23 (permalink) Old 02-08-2012, 06:00 PM
Hi Peter
I do enjoy making knobs of all types but I will say the big wing type like to snap off easy too small of mass around the center nut the norm but here's some links that you can use to make your own very easy and quick..that will stand up to the test of time.
I make most of them for the cost of the tee nut about 10 cents each or less and some scrap stock out of the bin, I have about 100 or so on hand most of the time but for the last year I have been using pop bottle caps ,it's just quicker and cheaper and they work just as well..
http://www.routerforums.com/attachme...e-100_2331.jpg
Hope this helps
Router Forums - View Single Post - Jig Storage & Shop made Knobs
http://www.routerforums.com/jigs-fix...joinery-3.html
post #6 of 23 (permalink) Old 02-08-2012, 09:11 PM
MEBCWD's Avatar
Hi Peter,
Here is a link to a supplier in the UK
from Rutlands.co.uk
Hope this helps,
MEBCWD is online now
post #7 of 23 (permalink) Old 02-08-2012, 09:17 PM
WOW !!
UKú 3.95 = 6.239815 U.S. dollars
Originally Posted by MEBCWD View Post
Hi Peter,
from Rutlands.co.uk
Hope this helps,
post #8 of 23 (permalink) Old 02-08-2012, 09:22 PM
darrink's Avatar
First Name: Darrin
Send a message via Skype™ to darrink
Here's another in the UK.
Components Direct
Darrin
Sealy, TX
darrink is offline
post #9 of 23 (permalink) Old 02-09-2012, 04:05 PM Thread Starter
Gaia's Avatar
First Name: Peter
Originally Posted by kp91 View Post
Peter,
Thanks.
Gaia is offline
post #10 of 23 (permalink) Old 02-09-2012, 04:06 PM Thread Starter
Gaia's Avatar
First Name: Peter
Hi Peter
Hope this helps
OK thanks for that.
Gaia is offline
First Box Joints w/a Hart Design Jig Wild Rag Jigs and Fixtures 2 03-23-2009 08:54 AM
