Swans Neck or Shape molding - Router Forums
post #1 of 5 (permalink) Old 02-22-2012, 04:13 PM Thread Starter
First Name: David
Default Swans Neck or Shape molding
Is anyone making Swans neck molding for Grandfather clocks or other furniture?
I have completed one set a few years back. Now up to 4 more sets may be needed.
Hoping to find out how others might make their jigs and fixtures. Unable to find any threads that address this process.
As a new member I can't show photos of my setup just yet.
Thanks David
c-123 is offline
post #2 of 5 (permalink) Old 02-22-2012, 04:19 PM
WoodworkersEdge.com Tool Tip - Making Gooseneck Moldings
Thanks David
Name:	G molding.jpg
post #3 of 5 (permalink) Old 02-22-2012, 08:40 PM Thread Starter
First Name: David
Default Swans neck
Thanks BJ
My setup uses a 1/2" router mounted above the workpiece. The router height is fixed about 2" above the lower table. A bearing on the lower table is used to guide the jig while routing. Verticle adjustment by the plunge router, while the router can be moved horizontally in line with the guide beariing. A router extension is required and multiple shallow cuts. Each molding set is almost one of a kind.
3 different router bits were needed for my molding.
Will post photos when I get my 10 posts.
Thanks David
c-123 is offline
post #4 of 5 (permalink) Old 02-22-2012, 08:55 PM
Hi David
You're Welcome You don't need 10 posted items to post pictures to the forum.
Thanks BJ
Thanks David
post #5 of 5 (permalink) Old 02-22-2012, 09:56 PM Thread Starter
First Name: David
Thats great. I will take some pictures for explanation.
Thhanks David
c-123 is offline
I need to make molding for drawer fronts stormbraceman Router Bits - Types and Usage 7 11-01-2012 07:40 PM
Router made case molding carpintero75wbp General Routing 4 12-06-2011 11:24 PM
ogee molding on a table rout1111 Table-mounted Routing 4 04-28-2009 05:32 PM
Molding, molding, and more molding DPLRBruno Show N' Tell 6 04-07-2009 08:49 PM
Advice on molding profile bits fasttruck860 Router Bits - Types and Usage 10 10-03-2008 10:52 PM
