Making Bow Tie Splines (Not Inlays) - Router Forums
post #1 of 7 (permalink) Old 03-03-2012, 06:01 AM Thread Starter
First Name: Eloy
Question Making Bow Tie Splines (Not Inlays)
I want to do a project where an element of the joinery would be bow tie splines. Does anyone have any suggestions on milling the splines? I could make some knives and do it on the moulder but it's for a small qty and different types of wood so I would like a fast setup. Since I want the spline to extend out like the tennon treatment on G & G designs an inlay is not my first choice. -Thanks
damnitboy is offline
post #2 of 7 (permalink) Old 03-03-2012, 06:56 AM
gav
Country: Croatia
First Name: Gavin
Not speaking from experience here, just what seems logical to me.
I would use a dovetail bit in the table.
Mill some stock to what ever width and depth you've decided on (width i guess would be twice the cutting height of your dovetail bit, and depth would need to be more than the diameter of the bit), length can be whatever, longer the better up to a point.
So, now you have a rectangular piece of wood.
Set up the dovetail bit so it will cut half way across the width of the stock. Set fence to half way point of dovetail bit. Zero clearance fence would be good in this instance.
Run the stock through on edge. Repeat , flipping end to end and top and bottom so you mill all four corners. You should end up with a really long bow tie shaped piece. Cross cut to desired size.
I guess it might even be quicker to set your table saw blade to your desired angle and do it that way.
I'm going to try it on monday just to see if my mind works.
gav is offline
post #3 of 7 (permalink) Old 03-03-2012, 07:37 AM Thread Starter
First Name: Eloy
Wow, Thanks for such a comprehensive reply. My first day on this forum, looks like a great community.
post #4 of 7 (permalink) Old 03-03-2012, 08:31 AM
Thumbs up
HI Eloy
All you need to do is pickup a bit or two and you can make all the bow tie splines you will need on the router table.. ..best done on the Horiz.router table but the normal router table will do just fine also..
Magnate 5401 14 Butterfly Spline Router Bits - 3/4" Cutting
Amana 45860 14 Degree Butterfly Spline 1/2 Router Bit
Sears: Online department store featuring appliances, tools, fitness equipment and more
Making the Most of Your Router Bits: The Butterfly Spline Bit | Articles | Woodworkers Journal
MLCS dovetail, candlestand router bits
Dave did almost the same. and it is a WOW look
http://www.routerforums.com/attachme...h-100_2073.jpg
post #5 of 7 (permalink) Old 03-03-2012, 09:36 AM
MEBCWD's Avatar
Hi elroy,
Does it really need to be a spline or could the joint be a standard woodworking joint and be covered with a decorative raised inlay to achieve the G&G look?
Make the project, cut the pockets for the inlays, make a inlay blank as Gavin says, contour the end of your inlay blank, cut the inlay piece off the blank and install the inlay.
That's how I would try to do it and just another way to achieve the look you want.
MEBCWD is offline
post #6 of 7 (permalink) Old 03-03-2012, 11:39 AM Thread Starter
First Name: Eloy
Bob, that was exactly the information I needed.
Thanks!!!
-Eloy
post #7 of 7 (permalink) Old 03-03-2012, 11:48 AM
You're Welcome Eloy
How about some snapshots of you using the bits
Thanks!!!
-Eloy
Dirty Little Secrets with Sign Making... newmexico Sign Making 45 06-18-2016 02:59 PM
Making Bow Tie Splines (Not Inlays) damnitboy Tools and Woodworking 5 03-03-2012 12:04 PM
Inlays and Sign Making for beginners mjdtexan Starting Off 3 11-15-2010 03:53 PM
Making keys with a router bow tie type Bogydave General Routing 20 12-14-2008 07:37 PM
