Should I keep or return my DELTA 17-924 Mortising kit - Router Forums
post #1 of 15 (permalink) Old 03-06-2012, 10:11 PM Thread Starter
First Name: Brett
Default Should I keep or return my DELTA 17-924 Mortising kit
So I was at Lowes tonight, actually looking for a very large socket I needed to work on a guy's truck I'm fixing, but I always have to look in the woodworking sections in hopes that something good is on sale or clearance. Well I found this one for $45+ my 10% off coupon which brought it down to roughly $40. I was pretty excited about the find, then reading the directions realized it won't fit my hybrid drill press, it's the one pictured where you add your own drill. Thinking I would look at getting a benchtop drill press so I could use this kit, I started looking at various reviews on this kit. A lot of them weren't very good so now I'm trying to decide if I should keep it or return it and just make them with my plunge router. I have no experience with mortise and tenon's but am very anxious to get started learning.
You can find the one I'm referring to here:
Amazon.com: DELTA 17-924 Mortising Attachment with 1/4 Inch, 5/16 Inch, 3/8 Inch, and 1/2 Inch Chisel and Bit Sets: Home Improvement
bclarknc is offline
post #2 of 15 (permalink) Old 03-07-2012, 06:19 AM
First Name: Keith
The one thing about reviews is the people that like the things they buy more than likly will not right a review.Mine is the next step down from your it did not have the chisels with it is the only difference.I have a Craftsman drill press which I don't use any of the collars mine fits without the collars.Do you have a drill press now?
Woodshaper67 is offline
post #3 of 15 (permalink) Old 03-07-2012, 09:22 AM Thread Starter
First Name: Brett
I do not have a drill press, just the type shown in the picture in my first post. I was thinking that if that one didn't work I would probably keep my eye out for a small one I can afford, which won't be a lot.
I agree with you about the reviews. I have not done many, positive or negative and have been telling myself I really need to since I rely on them so much for purchasing.
bclarknc is offline
post #4 of 15 (permalink) Old 03-07-2012, 10:24 AM
Bradleytavares's Avatar
First Name: Bradley
I went through the same decision making process regarding the same Delta accessorie. Through a number of conversations with woodworkers it came to light that a regular drill press will work in the short run but it's bearings wont handle the down pressure required to accomplish a mortice in hardwood. I saw a Delta dedicated mortice machine on sale so I bought it. Boy was I happy! The tool works by drilling out the center of a square and the chisle corners are forced through the wood to achieve a square opening. Now that I own the dedicated morticer I understand the down pressure issue. It takes a lot of pressure to perform the cut so if you can afford a single purpose tool you should buy it. As usual, a multi purpose tool does a lot of operations but none of them as well as a dedicated tool. Whatever your decision, enjoy your time working with wood. I've spent most of my life in saw dust and hope you receive as much pleasure as from it as I do.
Bradleytavares is offline
post #5 of 15 (permalink) Old 03-07-2012, 11:45 AM
Hi Brett
They work very well I have two of them ,the Delta and the Grizzly the Grizzly is little bit better than the Delta.it comes with more bits and more collars to fit more brands of drill press's
The key for me was to make a longer handle to take on the hardwoods easy..
Just one more way to use the tool,I'm not real big fan of the round dowel pins But I'm a fan of the square dowel pins that you can make easy and use the tool to put in the square holes...
If I want something to move I put it on a round pin if I want it Not to move I put it on a square pin or to say pin it with a square pin.
post #6 of 15 (permalink) Old 03-07-2012, 01:44 PM Thread Starter
First Name: Brett
@Bradleytavares...I'd love a dedicated mortising machine, but it's just out of reach right now. I was a custom cabinet make for a while and did some framing/trim work along with making some small pieces, so I do get a lot of fulfillment out of woodworking. I went on to major in photojournalism and now work at a paper, but the woodworking has been a part I have been missing out of my life and now am trying to get set up to do some furniture and art projects. So getting back in, money's an issue, anyone who knows about the journalism industry knows we don't always live comfortably, but I do love photojournalism, notice I didn't say my place of employment
@Bobj3...That's a big help, thanks for sharing that info with me. Any way you can email me those pics at full size?
Thanks again guys. I think I'll hold on to it, can't beat the price at $40, even if I use it a little and resell it I think I could get that out of it.
bclarknc is offline
post #7 of 15 (permalink) Old 03-07-2012, 03:01 PM
Garyk's Avatar
First Name: Gary
Brett,
You need to take a hard look at your need for making mortise & tendon joints. Only you can decide if it is worth the cost to you. I have had a dedicated Delta mortise machine for about 15 years. During that time I have used it maybe 5 or 6 times. There are other ways to make the joint without dedicated equipment. You got a good price for what you bought IF you use it enough to justify $40. But like you said, now you need a drill press just to use what you bought. That changes the bargain price a good bit.
Garyk is offline
post #8 of 15 (permalink) Old 03-07-2012, 03:38 PM
Bargains Finder
First Name: Tommy
I bought one as well at Lowes several months ago and took it back, I had it mounted to a Delta full size DP and its ,well quite frankly junk when it comes to mortising compared to a dedicated mortising machine. I recently got hold of a nice Craftsman Mortiser for $60 more than what you paid for that cast iron piece from Lowes and it will run circles around the old attachment type in a heart beat. The key to these tools however IMO is having the sharpest possible chisels to use. You can get a set of sharpening cones from Lee Valley for around $9 and they helped immensly as well as a newer set of chisels vs what they sell you in the kit. I'd return it and just shop around, something will turn up on CL and you'll never regret a dedicated machine, but mine doesn't get as much use as I thought it would and mortices are easy to make with a router as well. Just my 2 cents
Tommyt654 is offline
post #9 of 15 (permalink) Old 03-07-2012, 04:50 PM
Hi Brett
I think all wood workers go down the mortising trail with square ones and round end ones some like the square shoulder type and some don't ,I'm a fan of the floating type and some don't but you will need a drill press for wood working anyway and now you have a way to put in square ones ,it's true you can buy a dedicated tool for that job but why it's one of the items that you will just do now and than, it's like having a power hand saw or table saw they both will do the same job just fine just like your new mortising tool and if you want square holes you now can do it easy or you get out your chisel and hammer.
I have had my sets for a long (many years) and have not needed to sharpen them yet so to say the bottom line keep it you will be glad you did down the road just for that one job that you want to do I'm sure
Here's the going price for it so to say you got a deal, don't blow it off.
post #10 of 15 (permalink) Old 03-07-2012, 05:45 PM
MEBCWD's Avatar
Hi Brett,
I agree with Mr Jigs, I have the same set you bought and don't use it often but when I want to use it I have it.
You did get a good price on it!
Work safe, Have fun, Cut some wood,
MEBCWD is offline
Sold: New Delta 17-935 mortising attachment anniekirk Woodworking Classifieds 2 04-18-2011 06:49 AM
another kit or a dedicated table router? rprice54 General Routing 11 08-06-2009 07:51 AM
