Where in Aus to get double sided tape? - Router Forums
post #1 of 11 (permalink) Old 03-07-2012, 03:24 AM Thread Starter
First Name: Darryl
Default Where in Aus to get double sided tape?
I am looking at routing patterns off a template, and double-sided tape always seems to come up in such conversations in this forum. It seems like a good idea, but where do you get it, and what exactly do you ask for. The only double-sided tape I have used in the past would be totally unsuitable for this job.
I searched the Bunnings web site for "double sided tape" , and got shown some wonderful photos of double sided ladders. Both useful items, but hardly interchangeable.....
Darryl.
darsev is offline
post #2 of 11 (permalink) Old 03-07-2012, 06:32 AM
First Name: Col
Try the carpet shops as double sided tape is used by the installers of carpet. 3M site may also assist you. I ordered a roll with a couple of Whiteside bits from Woodcraft. Freight was't an issue as it saved on fuel & time.
Colj
Brisbane
Colj is offline
post #3 of 11 (permalink) Old 03-07-2012, 06:43 AM
Honored Member
harrysin's Avatar
First Name: Harry
Ebay has dozens of sellers here in Oz and elsewhere, this seems to be a decent link from Hong Kong, the seller has a good rating and I've had no problems buying from Hong Kong via Ebay, and if you have a PayPal account you are protected anyway.
free ship 5pcs 3M Scotch double sided tape 665 1/2x900 in 25yd | eBay
Harry
harrysin is offline
post #4 of 11 (permalink) Old 03-07-2012, 07:01 AM
Mufdi's Avatar
First Name: Ian
Bunnings have it in the paint section - just ask for it.
Mufdi is offline
post #5 of 11 (permalink) Old 03-07-2012, 07:02 PM
JOAT's Avatar
First Name: Theo
Hi. The other guys took care of where to get it. You could also use rubber cement. I've tried both, and like neither. They both hold well enough, it's just removing the residue after that irks me. I have seen where some people screw their patterns/templates down. I find it much hander to nail those things down. Honest.
I make my own patterns/templates for whatever I want to rout out. I make as perfect a pattern as I can, with 1/2" plywood, then glue it to a rough cut piece, and when the glue is dry rout out a 1" thick pattern, using a pattern bit. I call mine patterns, not templates. Then I drill however many small holes completely thru it, as nail guides. The nail holes are hidden in the final product, so you can be random if you want. I prefer a nail hole pattern, so if I decide to put the nail holes in sight after, they will form a pattern of sorts, rather than just random holes. I use 1 1/4" thin nails. I usually do not drive them flat, but no biggie if you do. I try to leave about 1/8" out, the total number of nails, depending on a variety of things, type of wood, complexity of design, size, etc. So at times you need to keep a close eye on the nails as sometimes they start to drift out. I use a small, 6" long, flat bar nail puller, that is the best thing I have found to pull the nails, and it leaves them straight - unlike a hammer. If the nails are too far in to pull, no problem, you can easily work the end fo the puller between the work and pattern, and gently pry them apart a bit, sometimes far enough to just pull them apart with your hands, sometimes just enough to use the puller on the nails. I realize my way is not for everyone, but works for me. Most of my router work lately is with wooden figure banks.
JOAT is online now
post #6 of 11 (permalink) Old 03-07-2012, 08:54 PM
Thumbs up
Darryl.
I always get mine from Bunnings.
It is made by Nortons, I think.
And, Yes, their web site is hopeless............
With the sealants and adhesives near the paint aisle.
Sydney, Australia
jw2170 is offline
post #7 of 11 (permalink) Old 03-08-2012, 02:50 AM Thread Starter
First Name: Darryl
Thanks gentlemen.
I will see what Saturday brings.
Darryl
darsev is offline
post #8 of 11 (permalink) Old 03-11-2012, 05:45 AM Thread Starter
First Name: Darryl
Got some double-sided tape from Bunnings. The tape worked well and I cut out 5 Gecko shapes in less than the time I had previously cut 2, even including experimenting to get it right. Ended up locking up the bearing on the trimmer bit I used. Not sure if it has actually siezed up or is just clogged up from the MDF dust - next weekend's project. MDF creates a lot of dust when routed I have found out... Think I have cleaned up enough to keep my wife happy.
darsev is offline
post #9 of 11 (permalink) Old 03-12-2012, 02:11 AM
Wink
Glad to be of service, Daryl.
We Aussies have to stick together.......
Sydney, Australia
jw2170 is offline
post #10 of 11 (permalink) Old 03-12-2012, 08:25 PM
JOAT's Avatar
First Name: Theo
My experience is that it probably seized up. Had that happen several times, so for some unknown reason starting putting a drop or two of Marvel Mystery Oil (that's what was handy) on the bearing before starting routing. No scientific evidence that it helps, except I have not had a bearing fail since I started doing that.
JOAT is online now
Double sided tape asrubin Table-mounted Routing 11 09-06-2015 07:24 AM
double sided tape FEARGI New Member Introductions 4 08-25-2010 10:54 AM
Double sided tape sankarmohan Lobby 16 12-11-2008 11:31 PM
double sided tape? falcn63 General Routing 4 01-17-2006 02:48 PM
Brads VS. Double Sided Tape Pop_pop1 Jigs and Fixtures 8 08-18-2005 06:11 AM
