My first knobs - Router Forums
post #1 of 11 (permalink) Old 03-09-2012, 12:07 AM Thread Starter
First Name: Chris
Default My first knobs
I made a couple of knobs tonight ...
This one is not really done yet, but the key desgign feature is that I glued the t-nut between the dowel and the handle, so there is no way that baby is coming loose:
I know ... big woop for you guys, but I'm proud of myself!
The other one is just a 1" dowel with a t-nut in the end. The thing Ilike about this approach is it can be either male or female:
Here are a couple of templates I made for maximizing the number of knobs you can get out of a 1x6 - it looks like you can get about 35 knobs (2 different styles) out of one foot of 1x6:
Chris Curl is offline
post #2 of 11 (permalink) Old 03-09-2012, 12:22 AM Thread Starter
First Name: Chris
Then again, I will probably learn the hard way that after you cut some of the holes, there isn't enough structure to be able to cut the others. Either that, or there is some order you need to cut them in that I won't know. So I'll probably make a mockery of it in real life.
post #3 of 11 (permalink) Old 03-09-2012, 12:52 AM
First Name: Jubilee
Interesting... please update with photos when you are done!
Doctor Atomo is offline
post #4 of 11 (permalink) Old 03-09-2012, 12:52 PM Thread Starter
First Name: Chris
will do ... i bought a piece each of 1x6 pine and maple today to play with tonight.
with luck, 30 holes with the hole saw will result in 38 knobs, most of which are rounded with 3 dimples, the others looking like 5 sided stars.
i intend to drill the pilots first, and then drill 1/2 way from the top and the bottom.
progress pics tonight, god (and the wife) willing.
post #5 of 11 (permalink) Old 03-09-2012, 03:08 PM
!...Are you going into knob manufacturing?! That there's a lifetime supply...
DaninVan is offline
post #6 of 11 (permalink) Old 03-09-2012, 04:22 PM Thread Starter
First Name: Chris
heh. but it's only 2 feet of a 1x6!
post #7 of 11 (permalink) Old 03-10-2012, 01:03 AM Thread Starter
First Name: Chris
1 1/4" and 3/4" dowels and t-nuts. the dowels are both 3/4" long. the 1 1/4" dowel hole is 3/8" deep.
drilled and size checked
test fitment
my stupid little "jig", just a holder for the larger dowel
larger dowels drilled
5/8" drill all the way through the smaller dowels. for some reason, I had a REALLY hard time lining up the jig to get the smaller dowels centered. this was definately a worthless jig.
snipping the points off the t-nuts. they will split the smaller dowel if not. but i left a little nib to catch.
tap the t-nut on the dowel
t-nuts installed, ready to glue
glued
all done!
post #8 of 11 (permalink) Old 06-16-2012, 12:14 AM Thread Starter
First Name: Chris
ok, question:
i have all these tops from the milk we drink that i have been collecting.
i think they would be good for knobs, but i'm not sure how to use them. thoughts?
post #9 of 11 (permalink) Old 06-18-2012, 01:03 AM
dask's Avatar
First Name: Kyriakos
Excellent job...
dask is offline
post #10 of 11 (permalink) Old 06-18-2012, 04:56 AM
japa62's Avatar
Did have one thought but after running out to the shed to test it, don't fold the pins back on a t-nut. They just break off. Might try it with some heat on the week end.
I did not realise how much fun making knobs can be and a excellent learning experience.
Oh, and top work Chris.
Under construction, always.
japa62 is offline
Knobs ~~~Bobj3 john880 Jigs and Fixtures 7 02-20-2012 09:55 AM
Golf Ball Knobs JerryPat Jigs and Fixtures 0 02-07-2011 09:30 AM
Star Knobs in Croatia istracpsboss Jigs and Fixtures 0 10-09-2010 03:51 AM
Bobj3 homemade knobs Tale Gunner Jigs and Fixtures 8 07-02-2008 12:36 PM
