Circular saw crosscut jig? - Router Forums
post #1 of 24 (permalink) Old 03-12-2012, 02:48 PM Thread Starter
GulfcoastGuy's Avatar
First Name: Patrick
Default Circular saw crosscut jig?
I'm in need of a plan for an accurate (possibly adjustable/calibratable) crosscut jig for use with a circular saw. I want to be able to test for square and tweak the jig to zero in on the squarest cut I can achieve. I have an idea but since I don't have enough posts to submit a drawing I thought I'd ask around.
GCG
GulfcoastGuy is offline
post #2 of 24 (permalink) Old 03-12-2012, 06:19 PM
First Name: Chris
i'd love to see one too.
as to squareness, the edges of the face plate are made to be parallel to the blade at the factory, and they are not adjustable (at least i have never seen one). if they are not parallel, you probably need a new saw.
so couldn't you just clamp a straight board to the piece you are cutting parallel to the cut you want to make? measure the distance from the edge of the blade to the edge of the faceplate, and then measure that distance on both ends of the piece and clamp the board there.
alternatively, bobj has a track and runner setup that makes sure the saw stays on the line.
Chris Curl is offline
post #3 of 24 (permalink) Old 03-12-2012, 09:01 PM
This is the simplest I have seen - use this one myself.....
MAKING STRAIGHT CUTS WITH A HOMEMADE JIG - YouTube
hardboard base with 1/2" ply fence.....
Sydney, Australia
jw2170 is offline
post #4 of 24 (permalink) Old 03-12-2012, 10:36 PM Thread Starter
First Name: Patrick
Thanks but that jig I have. What I need is one to make a crosscut at 90 deg. referenced to the straight edge that jig produces, preferably off a single measurement along that edge.
I've seen some on YouTube and elsewhere but they all assume a true 90 off a frameing square or the like. This is used to attach another fence on the underside perpendicular to the cut fence on the top. Once the 90 is established the reference fence is fixed to the jig with screws and glue.
The reference fence is registered to a straight edge of the panel or board and the cut fence sets up the 90 deg. cut.
What I have in mind is one step further. Do the initial setup with the frameing square but just clamp it in place. Drill and insert a dowel at the intersection of the two fences to be used to both anchor the two at that point and to provide a pivot point. Further toward the other end of the reference fence awat from the cut but still under the runner board (didn't know what else to call it) drill a pilot hole to act as a guide for a adjustment screw in the reference fence and a slightly oversized hole in the runner. The runner would be extra wide to have some meat on the side of the cut fence oposite the cut
Calibration:
With the screw holding the jig to the original square from the frameing square, make a cut on a test board. Flip the test board horizontally keeping the reference edge against the reference fence and make a cut on the other side of the test board. Assuming some error in square the length measured at the base of the test board and the top will be different by twice the amount the jig is out of square. Loosen the adjustment screw for a friction contact, move the refernce fence to correct, retighten the screw and repeat the proceedure. When you reach the level of accuracy desired another dowel can be inserted near the screw to lock the jig in place and other screws can be used for reinforcement.
GCG
post #5 of 24 (permalink) Old 03-13-2012, 01:39 AM
Square-Cut
You might be thinking of something along these lines.
Or attach a batten at right angles to the jig in the previous video. Once it's set, its set....
I mark a line with the framing square and then line my jig up on that line, then clamp in place....
Sydney, Australia
jw2170 is offline
post #6 of 24 (permalink) Old 03-13-2012, 08:48 AM
Gene Howe's Avatar
First Name: Gene
That's a neat jig, James. If I were cutting a lot of 2X material, I think $11 would be a great investment. As it is, I just align my saw blade with the cut line and slide the "Speed Square" to the saw plate.
For anything wider than 12", I use my red neck track saw.
Gene
Originally Posted by jw2170 View Post
Square-Cut
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #7 of 24 (permalink) Old 03-13-2012, 08:56 AM
First Name: Chris
just take a 18" piece of 1x4 and a 18" piece 1x2. make sure they are perfectly straight. glue and screw them perpendicular to each other near one end of the 1x4 piece. make sure it is exactly 90*. how you make them exactly 90* is up to you. there are lots of ways.
then run the saw along the 1x4 piece to cut the 1x2 piece at the blade. there is your jig.
now all you have to do is line up the edge of the cut off part of the with your line and clamp it in place. it would look like this:
post #8 of 24 (permalink) Old 03-13-2012, 12:43 PM
Ken Bee's Avatar
First Name: Ken
Here is a fairly simple circular crosscut jig if this what you had in mind.
Name:	Circular Saw Crosscut Guide.jpg
When something is advertised as being foolproof there is always a better class of fool that comes along to prove them wrong.
Ken Bee is offline
post #9 of 24 (permalink) Old 03-13-2012, 03:00 PM Thread Starter
First Name: Patrick
@James
I've seen the Square Cut. Bench Dog and Stanley both have similar products and that's what I'd go with if the pieces were narrow ... up to say 12". I'm going to have panels at around 20" - maybe more. I have two framing squares and both are off by more than a thin pencil mark at 24". I guess I could pop one of them with a punch a couple of times and see if that corrects the error. Then I could use that to make the batten modified jig that you and, later, Chris described.
Thanks all for the input.
GCG
post #10 of 24 (permalink) Old 03-13-2012, 03:53 PM
I'm guessing you considered a good quality drywall T square?
Wal-Board Calibrated T-Square 54 in. - 1/8 in. WTS-54 (WLB-88-016) | WallTools.com
Obviously you wouldn't be able to make the sawcut without damaging the Tee, but they're sure convenient for the layout part.
Unlike a framing sq. the Tee arm is undermounted making for a really solid contact with the reference edge...not prone to slipping off.
I use mine for plywood layout as well as drywall; no complaint.
DaninVan is offline
Adjustable Jig for Crosscut Sled curiousgeorge curiousgeorge's Gallery 9 11-12-2013 03:30 PM
