jigs made keeping me busy - Router Forums
post #1 of 11 (permalink) Old 03-13-2012, 03:35 PM Thread Starter
First Name: Lito
Default jigs made keeping me busy
Since I finished my router table, I've been makng some jigs that keeps me busy.
fishuntbike is offline
post #2 of 11 (permalink) Old 03-13-2012, 03:53 PM
OPG3's Avatar
First Name: Otis
Lito - that is some good-looking work! With properly planned and constructed jigs - almost anything done with a router can be done better. Keep-up the good work!
OPG3
Tweak everything!
OPG3 is offline
post #3 of 11 (permalink) Old 03-13-2012, 06:39 PM Thread Starter
First Name: Lito
thanks
post #4 of 11 (permalink) Old 03-13-2012, 11:00 PM
The jig looks good, need to added blind mortising capability. What is the first image above, could you expand the image?
Rick
res005ru is offline
post #5 of 11 (permalink) Old 03-13-2012, 11:01 PM
Forgot one thing, the hardware you used, what are they and where did you get them?
Rick
res005ru is offline
post #6 of 11 (permalink) Old 03-15-2012, 05:00 PM Thread Starter
First Name: Lito
The first one is a coping jig and all knobs are from rockler.com the secong one is exact dado jig and the last one is circle jig for bandsaw
post #7 of 11 (permalink) Old 03-19-2012, 08:10 AM
#! & & #3 are interesting, however your dado is similar to mine. What I did is use two boards at 66 " long each. The two smaller boards you have on the bottom, I put on top. I added a t slot one inch inside the outside edge. This has the following requirements:
1 You must clamp the stationary board to a work area and support it at the size of work piece.
2 If you require a blind mortise, as I currently do on my current project, My adjustable slots allow the small boards to set the end points for the router, also the width of the mortise on all sides.
Rick
res005ru is offline
post #8 of 11 (permalink) Old 03-20-2012, 02:53 PM
First Name: Roy
Good looking jigs Lito. Keep um coming. Roy
olwudwurker is offline
post #9 of 11 (permalink) Old 03-20-2012, 08:34 PM
First Name: Chris
heh ... making jigs keeps me busy too. unlike yours, mine are pitiful and amaturish though.
if i ever actually DO make something with this stuff, it will really be something to celebrate!
Chris Curl is offline
post #10 of 11 (permalink) Old 03-21-2012, 09:56 PM Thread Starter
First Name: Lito
I made another circle jig for router table use
  LinkBacks (?)
LinkBack to this Thread: https://www.routerforums.com/jigs-fixtures/34383-jigs-made-keeping-me-busy.html
Posted By For Type Date
Untitled document This thread Refback 03-13-2012 10:55 PM
Amish Made? xplorx4 Lobby 9 01-28-2012 08:42 PM
Hand made wood plane locoboy Tools and Woodworking 10 02-16-2010 05:49 PM
Some turning tools that I made Mitch12 Woodturning and Lathes 16 11-15-2008 10:29 PM
What is the white material all your jigs and fences are made of? paulcomi Jigs and Fixtures 16 05-19-2006 11:05 AM
What jigs do you find most useful? paulcomi Jigs and Fixtures 15 10-10-2004 10:09 PM
