Wodd Lathe router jig - Router Forums
post #1 of 4 (permalink) Old 03-18-2012, 09:21 AM Thread Starter
Country: South Africa
First Name: Kenneth
Default Wodd Lathe router jig
Hello All
I am a novice wood turner with arthritis. I need to construct a jig or jigs so that I can use a router to shape the inner and outer of a bowl. I have seen a few ideas but they are not very versatile. I want to be able to do everything one can do with standard chisels. Originally I thought about using a cross vise on a swivel to hold the standard chisels but then someone suggested using a router instead.
The ultimate would be a rig similar to the rig of an operating theater overhead light with a router at the end instead of the spot lights. Something that would absorb all the 'chatter' and allow small/slow incremental movement with the precision of a surgeon.
More realistically I see a platform with a router mounted on its side devoid of plunge mechanism to allow access to the shape and form of a bowl.
I think the key here is versatility and simplicity. I believe that the ideas of a novice have usually been perfected by a craftsman, so I am calling on All to assist me in my quest.
Best Regards
Kas2401 is offline
post #2 of 4 (permalink) Old 03-19-2012, 01:26 AM
Welcome to the router forum.
Thank you for joining us, Kenneth.
Sydney, Australia
jw2170 is online now
post #3 of 4 (permalink) Old 03-20-2012, 07:04 AM
First Name: Steve
Hi Kenneth - I recently became interested in making bowls using a router after seeing an episode of the Woodsmith Shop (woodsmithshop.com) on TV. They used a special bowl router bit from a company called CMT. They also make a collet extender for deeper bowls. There is a video at the Woodsmith website. Look under "Episodes" until you find the routed bowl episode. Also check the website at drygulchexoticwoods.com/routedpieces.html. Beautiful bowls. The only problem is that the bowls are limited to having straight sides (unless someone has figured out how to route slanted sides). There is also a website that says bowls can be made with a router and jigsaw (lumberjocks.com/projects/7664) and they recommend a book by 2 authors. The only other alternative is a very expensive rig made by Legacy which can be viewed at legacywoodworking.com. It can do everything with a router. I imagine it will make bowls too. Watch the demo video. Good luck. My wife has arthritis in her hands also. It's miserable. Hope you find something that works.
Steve B. is offline
post #4 of 4 (permalink) Old 03-26-2012, 01:53 AM Thread Starter
First Name: Kenneth
Thankyou. Look forward top everything you guys can share. Best Regards
Kas2401 is offline
For Sale: Rockler Ellipse/Circle Router Jig dovetail_65 Woodworking Classifieds 8 03-13-2013 07:00 PM
Router jig for a wood lathe cleteboothby Jigs and Fixtures 12 03-19-2012 06:41 PM
Router Lathe bobj3 The Bargain Bin 9 06-24-2009 03:12 AM
