Dado Jig - Router Forums
post #1 of 12 (permalink) Old 03-20-2012, 05:24 PM Thread Starter
First Name: Peter
Default Dado Jig
Hi
Just completed my router dado jig. Made it out of what I had to spare - 12mm ply, pine and Tasmanian oak.
I made the far end flush so it can sit on a wider surface - maximum length of the dado is about 810 mm and maximum width 54 mm using a 8mm router bit. Knobs are on top and the two stops at each end stop the router going through the end supports.
Peter
Name:	Router Dado Jig.JPG
Name:	Router Dado Jig 2.JPG
Aragocom is offline
post #2 of 12 (permalink) Old 03-20-2012, 09:05 PM
Welcome to the router forum.
Thank you for joining us, Peter.
you will find that jig very useful.
Sydney, Australia
jw2170 is offline
post #3 of 12 (permalink) Old 03-20-2012, 11:56 PM Thread Starter
First Name: Peter
Thanks James. Just used it for the first time and very happy with the ease of setting up and cutting a groove (making a tablesaw sled).
Aragocom is offline
post #4 of 12 (permalink) Old 03-21-2012, 10:16 AM
First Name: Roy
Great looking jig. I've seen plans for something like this but they show the knobs under the end pieces. Yours look like a better take on the subject. Roy
olwudwurker is offline
post #5 of 12 (permalink) Old 03-23-2012, 06:21 AM Thread Starter
First Name: Peter
Thanks Roy
The jig was built to cut several stopped grooves across / along a large homemade tablesaw top for T-tracks where the dimensions are greater than the jig's. Hence the knobs on top and the flush far end.
Of course does just as well on smaller pieces ....
Peter
Aragocom is offline
post #6 of 12 (permalink) Old 03-23-2012, 03:46 PM
OPG3's Avatar
First Name: Otis
Peter, that is in my opinion the single best way to make a dado cut! By the way, dadoes go across grain and grooves go along grain. When it is plwood I have no idea of the proper name! This jig can make dado and groove cuts. I've been using one like this for many years (mine is much simpler) and it never fails me - I just have to remember to always load my router with a 1/2" diameter bit (which is always smaller than the width I am routing). Your jig pictured here looks very nicely made! Keep-up the good work!
OPG3
Tweak everything!
OPG3 is offline
post #7 of 12 (permalink) Old 03-23-2012, 04:03 PM
http://www.routerforums.com/jigs-fix...ge-router.html
post #8 of 12 (permalink) Old 03-23-2012, 04:11 PM
Greyone's Avatar
Very nice Peter, I assume the knobs are for adjusting to the size of the bit?
Greyone is offline
post #9 of 12 (permalink) Old 03-25-2012, 07:17 AM Thread Starter
First Name: Peter
Bill
No the jig always uses one particular bit - in this case a 5/16". The final step in setting the jig up before use is to run the router with the chosen bit down each rail to trim the inside face of the rail. As long as you use the same router bit and keep the same edge of the router against the same rail every time then the inside faces are always the extent of the cut. The router I am using here has two flat sides so it makes it easy.
The knobs are to there adjust the width of the cut - just drop what you want to fit into the groove between the rails, squeeze the rails together and tighten the knobs. Then line up the inside face on your line (with the groove on the correct side !), clamp and cut.
I looked at the one detailed in the link by bobj3 but the ability to just adjust to size and clamp to the line won the day - foolproof (well almost) with no calculations. As I said my router has two flat sides so I don't get jams and it also doesn't have provision for a guide bush.
Aragocom is offline
post #10 of 12 (permalink) Old 03-25-2012, 02:56 PM
01stairguy's Avatar
First Name: Ron
nice job peter
01stairguy is offline
Router Adjustable Dado Jig Barry_White Jigs and Fixtures 18 07-20-2010 03:36 PM
Bj's Dado Jig RustyW Jigs and Fixtures 1 10-06-2009 05:09 AM
