what hp for router thickness planing using skis - Router Forums
post #1 of 8 (permalink) Old 03-21-2012, 01:51 AM Thread Starter
First Name: tom
Default what hp for router thickness planing using skis
I am interested in building a set of skis for my dewalt 611pk with the intent of doing some limited thickenss planing and perhaps cutting some slots.
Is this router too much of light weight for planing task.........reducing 3/4 red oak to 1/2 inch
tomcoleman is offline
post #2 of 8 (permalink) Old 03-21-2012, 07:39 AM
Honored Member
harrysin's Avatar
First Name: Harry
I.25hp is on the light side for any serious routing, especially planing hard woods. When you next buy a router choose one that's 3-3.25hp and it will be capable of completing any task you ask of it.
Harry
harrysin is online now
post #3 of 8 (permalink) Old 03-21-2012, 11:49 AM
Hi Tom - I agree a big router would be better. The 611 would probably do it if you're careful with the depth of cut and size of cutter. Personally, I use the 2.25 HP Freud.
John Schaben
jschaben is offline
post #4 of 8 (permalink) Old 03-21-2012, 12:39 PM
Hi
For me it's not the size of the router it's the size of the bit you can use in the router the 611 is a 1/4" shank router bit only, the 611 has a ton of power BUT the biggest one you can use is 3/4" one ,the max without over loading the router..
post #5 of 8 (permalink) Old 03-21-2012, 12:54 PM
Ken Bee's Avatar
First Name: Ken
Like John said using the trim router probably wouldn't be a good idea unless you plan on skim planing hardwood stock.
I just set up my Woodhaven planer yesterday to bring down a lot of 3/4 stock to 5/8 and 1/2 using a 2-1/4 HP Hitachi M12VC router. I use a 2-1/4 diameter Drawer Lock Bit in the Hitachi to plane the stock and keep the cuts less than 1/32 in hardwood. I tried 1/32 in Ambrosia Maple and didn't like the way the router sounded so I reduced the depth of the cut. Ambrosia Maple is a heck of a lot softer than Oak,especially Quarter Sawn White Oak, Birdseye Maple and some of the Exotic Hardwood I have to plane in the next few days.
When something is advertised as being foolproof there is always a better class of fool that comes along to prove them wrong.
Ken Bee is offline
post #6 of 8 (permalink) Old 03-21-2012, 01:19 PM
RJM60's Avatar
First Name: Robert
A 3+ HP router might be a bit heavy for most of the skis I see on this forum. The problem is that most skis have rods that go thru holes in the router base. The router base holes are designed for small, lightweight attachments like a edge guide, not for rods to support 1 12-15 lb router. So I would suggest a 2 HP router, or a stouter ski jig (to minimize bounce - i.e. flatter surface on work piece).
Note: Bit size and depth of cut will determine how much power you need and how nice the finish is. Smaller diameter nbits and lower depth of cuts will reduce power required and increase finish quality.
“The single biggest problem in communication is the illusion that it has taken place.”
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
post #7 of 8 (permalink) Old 04-01-2012, 08:03 PM
First Name: Brett
What about a 1 3/4 hp one? Just bought a ryobi plunge one for 8 bucks and wouldn't mind just having it dedicated. I have a 2 hp craftsman if not. I really need to do this because I'm about to buy a stack of rough oak, but you guys have me worried I won't have enough power.
bclarknc is offline
post #8 of 8 (permalink) Old 04-02-2012, 05:52 PM
ggom20's Avatar
Country: France
First Name: Gerard
Hello Tom!
You will probably be able to to it even with little router.
Let us know how it did.
About skis made of steel rods , it could be a bit flexible, and
I' ve noticed on my router that when thightening the screws on steel rods,
the router get inclination, not stay horizonal, this would give a bad finish.
a curved edges router bit is better for finish, like a bowl cutter.
Straight bit could do, but with more sanding.
Flexibility is another cause of bad finish.
Skis made of plywood or wood could do better,
even if it makes things difficult to see, there is not much to be seen..
Regards.
ggom20 is offline
First router suggestions (for thickness planing and cabinetry) bokubob General Routing 13 10-17-2011 10:22 AM
Use of skis to thickness wood? rcp612 Jigs and Fixtures 8 05-22-2010 02:13 PM
Router Skis....again Al Robins Lobby 48 05-10-2010 10:41 AM
router bit for use with skis to thickness wood rwyoung Jigs and Fixtures 19 02-14-2009 09:22 AM
skis for neophytes allthunbs Jigs and Fixtures 36 01-11-2009 09:40 PM
