Router coping sleds - Router Forums
post #1 of 12 (permalink) Old 03-25-2012, 12:53 AM Thread Starter
Smile Router coping sleds
I am in the process of redesigning my router table top and I would like to know if a coping sled uses the mitre track or the fence to guide it?
Also does anyone have any plans how to make one?
Thanks.
Punchright is offline
post #2 of 12 (permalink) Old 03-25-2012, 09:25 AM
Honored Member
First Name: pat
In my case: The fence.
Quillman is offline
post #3 of 12 (permalink) Old 03-25-2012, 07:21 PM
First Name: Lito
I use fence and I made a coping jig like this
fishuntbike is offline
post #4 of 12 (permalink) Old 03-25-2012, 09:23 PM
Thanks.
Hi Mike - Welcome to the forum
You can use either, just don't try to use both
Here's a link to a plan for a fence guided sled
Shop-Made Coping Sled : Projects
John Schaben
jschaben is offline
post #5 of 12 (permalink) Old 03-27-2012, 12:42 AM Thread Starter
Ok thanks.
post #6 of 12 (permalink) Old 03-27-2012, 12:43 AM Thread Starter
Thanks for sharing those pictures, did it take long to make?
post #7 of 12 (permalink) Old 03-27-2012, 12:50 AM Thread Starter
Thanks John, that looks a work of art, fantastic detail. So I take it that these sleds are much better than feather boards? Why is the base such an odd size though?
post #8 of 12 (permalink) Old 03-27-2012, 01:00 AM
Hi Mike
See the link for the CMT videos,on the bottom of this post they will show you how to make a very simple coping sled and how to use it with the fence and the tee tack and how to setup it up the stick way..when using the tee track..
Make your coping jig the KISS way and you will use it, you don't need one that has all the knobs and hold down devices just so much more stuff you don't need I will say I'm not a real big fan of the coping jig, you just about always need to reset the router or to say adjust the router up or down and that will always put in a error in your joints,,,,, .005 is a big deal with router bits..they are ground dead on the norm ..
http://www.sommerfeldtools.com/somme...log/page03.pdf
Thanks.
post #9 of 12 (permalink) Old 03-27-2012, 03:33 AM
wbh1963's Avatar
Mike,
Thanks for starting this thread! I had no idea these things even existed, so thanks to the help of the others, I have leaded a bit more from the read.
wbh1963 is flowing with the grain in Arlington, Washington, USA
A day without curls is like a day without sunshine!
wbh1963 is offline
post #10 of 12 (permalink) Old 03-27-2012, 11:31 AM
Ken Bee's Avatar
First Name: Ken
Here is the one I built out of mostly flea market parts for, if I remember correctly, less than $25.00 and it does ride in the T-Track on my table. I have since modified it a bit, such as making the base longer so it will accept 8 inch wide stock and adding another clamp. I don't use it as intended, but mostly as a small parts holder to cut slots and miter joints in end grain for my boxes and clocks.
I also have the plan than John linked to and am seriously considering building it.
When something is advertised as being foolproof there is always a better class of fool that comes along to prove them wrong.
Ken Bee is offline
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Milwaukee 5625-20 15 Amp 3-1/2-Horsepower Fixed Base Variable Speed Router Review woodrouterreviewsguy Tool Reviews 1 02-23-2012 10:35 PM
Coping Sleds Question Timmberman Table-mounted Routing 5 08-15-2011 05:03 AM
