Please help me make a jig. - Router Forums
post #1 of 3 (permalink) Old 03-30-2012, 10:36 PM Thread Starter
First Name: mark
Default Please help me make a jig.
I have been trying to make a jig today to cut a 7.5"x2.5" recess in a 8.5"x3.5" piece. I figured that since my router base is 6", i just add that to my length and width and that would give me the size I need. Then I realized I was not taking into account the size of the bit i was using. I am using a 1/2" bit so I subtracted that from my measurement and it still isn't quite right. Any tips would be great. Thanks!
black3000gt is offline
post #2 of 3 (permalink) Old 03-30-2012, 10:45 PM
The Warthog's Avatar
First Name: Roger
You may have taken the whole " diameter of the bit away from the edge of the jig. In fact, if your baseplate is 6" and the bit is ", then the edge of the baseplate is 2 3/4" from the edge of the bit. That is, 3" from the centre of the baseplate and bit to the edge of the baseplate, minus " from the centre of the baseplate to the edge of the bit. Your stop block needs to be 2 3/4" from the edge of the planned recess. Measure this with a ruler before you set out the edges of your jig.
Cheers,
Roger
I'm not slow, I'm pacing myself!
Isaiah 44:13 Another shapes wood, he extends a measuring line, he outlines it with red chalk. He works it with planes and outlines it with a compass...
Usual kit: Table saw, band saw, dual base router and table, lathe, various saws, planer, sanders, and a multitude of hand tools.
The Warthog is offline
post #3 of 3 (permalink) Old 03-31-2012, 09:14 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
This is how I rout a recess using a template and guide. To calculate the size of opening in the template, guide dia. minus bit diameter plus the size of the recess.
If you used a 1" guide and a 1/2" bit, then: 1-1/2+7.5=8"...1-1/2+2.5=3"
so, a template with a cut-out measuring 8" x 3" using a 1" guide and a 1/2" bit will give you the required size of rebate. The first shot shows the easy way to make a template with an accurate cut-out.
Harry
harrysin is offline
EZ Dovetail Jig bobj3 Jigs and Fixtures 12 01-14-2020 07:20 PM
How to Make a Picture Frame learnexperience Table-mounted Routing 10 09-24-2011 04:48 AM
Sliding Mortise Jig Glen L Jigs and Fixtures 6 02-23-2011 10:11 PM
Bj's Dado Jig RustyW Jigs and Fixtures 1 10-06-2009 05:09 AM
