Need advice about table saw sled build - Router Forums
post #1 of 6 (permalink) Old 04-13-2012, 11:42 AM Thread Starter
First Name: Chris
Default Need advice about table saw sled build
hi everyone,
just need a bit of advice from those a bit cleverer than me.
ive been trying to build myself a table sled for my new table saw, had i about a month, an erbauer, a really good saw.
my problem is making the wooden runners, the rest of the sled is no problem.
i cannot seem to make the runners a perfect fit, its usually way too tight, youll see in the pics why its a bit of a bugger to make them fit well.
as in the pics, the table saw slots are not straight open slots, they have a few metal ridges that come out along the track, this for me, makes it very difficult to get precise fittings for the runner. obviously, without these little edge bits it would be a piece of cake.
anyway, does someone have any good tricks i could use to sort this out.
ive thought of cutting the ridges off, but as its a new tools, im a bit loath to do this.
any help welcome.
thanks.
trojan62 is offline
post #2 of 6 (permalink) Old 04-13-2012, 11:59 AM
?...are they full depth (vertically)? Just a guess but are they supposed to stop channel accessories from tipping out, sort of like a 'T' slot?
If they are, then the critical dimension is the width measured at the bottom of the slot. You'd probably want some clearance as your runner goes past the 'nubs' (?)...
If it were me I'd be looking for purpose made runners from the manufacturer!
They designed it; they should have the solution.
DaninVan is offline
post #3 of 6 (permalink) Old 04-13-2012, 12:05 PM
If you can't get an answer here, at this forum, try this one from Ol' Blighty...
www.ultimatehandyman.co.uk • View topic - Erbauer tools
DaninVan is offline
post #4 of 6 (permalink) Old 04-13-2012, 12:12 PM
Hi Chris
Easy fix make your guides in the 2 step way, I use 1/4" thick plastic for the bottom one and 1/4" thick plastic for the top one..see in the picture below,,,but Oak will work for both..just use small screws with nuts to hold both parts to your table sled..
Or you make it out one part and put a rebait (rabbit) in place for the top part of the guide..little bit of wax on the guide and it will slide nice and free in the slot..
Originally Posted by trojan62 View Post
hi everyone,
any help welcome.
thanks.
post #5 of 6 (permalink) Old 04-14-2012, 12:17 PM
stanzee's Avatar
First Name: Stan
I milled the oak to fit the widest part of the table slot and put a rabbett on both sides to provide clearance for the ears. Woirks great for my purposes.
stanzee is offline
post #6 of 6 (permalink) Old 05-18-2012, 04:48 PM
JCJCJC's Avatar
Country: Ireland
I have identical tracks on my Hitachi tablesaw. I found stock steel bars in a local steel stockists that fit perfectly, cheap and dead-easy to make jigs with them. I drilled and tapped M6 holes and used countersunk socket-head screws to attach the jig to the rails, with a few washers as spacers to get past those ridges you mention. Sorry, I've no pics.
JCJCJC is offline
New(first) Table build - need advice Ash Table-mounted Routing 6 11-14-2011 02:03 PM
First Router Table -- Buy or Build ? mbhere Table-mounted Routing 8 11-07-2010 09:09 AM
table sled for mitre cuts jw2170 Tools and Woodworking 23 05-31-2010 09:46 PM
Build table for Bosch router taa800 Table-mounted Routing 11 02-24-2009 09:48 PM
