Centering a square cap jig - Router Forums
post #1 of 16 (permalink) Old 04-20-2012, 09:11 AM Thread Starter
First Name: Steve
Default Centering a square cap jig
Hello all, may I pick your brains?
I work for a large stair manufacturer and we've been racking multiple brains to come up with a simple, efficient jig for the following:
A specific style of post we make requires that we pre-drill in the exact center of the underside of the post cap. They are always square, but come in varying sizes, and these sizes sometimes have a 16th variance due to shrinkage. What we're trying to come up with is a jig for use with a drill press that would center the drill bit on the cap regardless of differences in size, for rapid mass-production. If they were all identical all the time it would be no problem.
The ideas we've come up with so far have either been far too complicated, awkward to employ, or require advanced engineering techniques we're not sure exist...
Any ideas here?
safetysteve403 is offline
post #2 of 16 (permalink) Old 04-20-2012, 07:47 PM
CharleyL's Avatar
First Name: Charley
Carefully drawn lines from opposite corners will form an X in the exact center. Then drill your hole there. A jig isn't necessary. Another possibility is to use a lathe center marking jig like this one, but it won't work very well if the cap isn't perfectly square.
Amazon.com: Woodstock D3098 Center Finder: Home Improvement
Charley
Central North Carolina
CharleyL is offline
post #3 of 16 (permalink) Old 04-20-2012, 08:15 PM
Country: Japan
First Name: singh kuldeep
Send a message via Skype™ to samurai
bridge city thet have drilling jig for this kind of task.expensive but very nice.have a look on video
samurai is offline
post #4 of 16 (permalink) Old 04-20-2012, 10:01 PM
First Name: Duane
A large version of this?
Dmeadows is offline
post #5 of 16 (permalink) Old 04-21-2012, 06:00 AM
How about this? Make a square box with no bottom or top that is ~1/2" larger than your largest cap. Make the sides tall enough to contact the flat edges of the cap. Center this under the drill bit on the drill press. When you insert the cap to be drilled, rotate it so all 4 corners are touching the sides of box and you will be centered.
michmags is offline
post #6 of 16 (permalink) Old 04-21-2012, 07:46 AM
First Name: Andy
Try rilling the hole then squaring the top from a centre pin tahtshould be perfect
Andy
andy's Den is offline
post #7 of 16 (permalink) Old 04-21-2012, 07:46 AM
First Name: Art
Instead of trying to center different size stock why not plan each post to a standard size and then go from there.
mgmine is offline
post #8 of 16 (permalink) Old 04-21-2012, 06:32 PM
JOAT's Avatar
First Name: Theo
Yep, that's the way I'd go. You guys apparently forgot the acronym K.I.S.S.
Keep It Simple Stupid.
JOAT is online now
post #9 of 16 (permalink) Old 04-21-2012, 07:15 PM
rwl7532's Avatar
First Name: Ralph
Looks to me that many replies have missed this phrase.
How many seconds each cycle? (Item into jig and desired adjustment time until drilling begins)
rwl7532 is offline
post #10 of 16 (permalink) Old 04-21-2012, 07:52 PM
Think you're on to something but the box should probably have some sort of leveling "shelf" to allow a bore square to the plane of the cap. The jig can have a centered peg that aligns with the bit on the drill press. (think pin routing)
If the caps have a profile on top that hinders a flat just drop it in and turn motion then the boring might be better done from below.
TomE is offline
First Box Joints w/a Hart Design Jig Wild Rag Jigs and Fixtures 2 03-23-2009 08:54 AM
