i need a jig that will cut a concave curve on a thick board - Router Forums
post #1 of 10 (permalink) Old 04-23-2012, 07:44 PM Thread Starter
notLefty's Avatar
First Name: NotLefty
Send a message via Yahoo to notLefty
Default i need a jig that will cut a concave curve on a thick board
i want to make a low bench 8" wide, 18" long, about 3-4" thich with a curved concave top, sorta Asian style.
i saw an old fuzzy photo from an old book, of a jig that did that, on line, but i lost it.!!
it had a base guide each side of the curve desired, looked like the router was on a little sled with arms that rode on the base.. back and forth, moved side to side over the board to route it down.. it wasn't clear at all. i dont know enough about routers to figure out how to do that safely.
has anyone ever seen something like that.? got a link>> ??
notLefty is offline
post #2 of 10 (permalink) Old 04-23-2012, 08:21 PM
Try searching this forum for "router skis". That sounds like what you were looking at.
post #3 of 10 (permalink) Old 04-24-2012, 01:43 PM
allbarknobite's Avatar
First Name: Mark
Default A vertical bandsaw cut on your board would do 95% of the work
Hi NL,
A single vertical bandsaw cut on a 2-inch by 8-inch by 18-inch board would do 95% of the work of making the top. If your bandsaw cannot handle 8 inches, then you could cut and glue up two 4 inch boards. Your router can then finesse the edges.
Mark
allbarknobite is offline
post #4 of 10 (permalink) Old 04-24-2012, 06:44 PM
pal
pal's Avatar
First Name: Harold
Hi NL,
Try this link http://www.finewoodworking.com/media/MethodsOfWork.pdf
Regards
Harold
Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning.
Albert Einstein
pal is offline
post #5 of 10 (permalink) Old 04-25-2012, 04:41 PM
Country: Poland
First Name: Dominik
DominikPierog is offline
post #6 of 10 (permalink) Old 04-25-2012, 06:16 PM
Think of the pit and the pendulum,you don't need a DVD to make a simple jig to hold the router for you.
Or
If you have a RAS it will do the job fine or you can mount a router to the RAS..
pit and the pendulum - Google Search
http://www.ebay.com/itm/1-pc-1-2-SH-...item20c26bda31
post #7 of 10 (permalink) Old 05-26-2012, 08:31 AM
dutchman 46's Avatar
First Name: Howard
I know that this is late, Take a look at Woodsmithshop.com or in the book It is what You are looking for. Fairly easy to make, I think!
John 3:16
dutchman 46 is offline
post #8 of 10 (permalink) Old 05-26-2012, 08:49 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
That jig Harold should lend itself to all sorts of projects.
Harry
harrysin is offline
post #9 of 10 (permalink) Old 05-26-2012, 08:57 AM
harrysin's Avatar
First Name: Harry
$19.00 for that 2 3/4" Crown moulding bit is a bargain Bob.
Harry
harrysin is offline
post #10 of 10 (permalink) Old 05-26-2012, 05:17 PM
pal
pal's Avatar
First Name: Harold
Hi Harry, I have used it to make half a dozen small benches out of hoop pine (450mm high x 600mm long 450 mm wide) with a foldable tray for a friend, he uses them in the barbeque's area rather than plastic chairs, also 2 garden benches 1200mm long that also gets utilized at his barbeque's.
Regards
Harold
Albert Einstein
pal is offline
question Henry Fernandez Starting Off 14 02-11-2008 05:46 PM
New Lower Priced Leigh Dovetail Jig scrollwolf Jigs and Fixtures 1 07-08-2007 05:10 PM
short dado's krimson_cardnal Jigs and Fixtures 16 06-13-2006 12:28 PM
Base board cope cut cbraby Jigs and Fixtures 4 12-07-2004 03:57 PM
