Need some help locating a blade - Router Forums
post #1 of 5 (permalink) Old 05-02-2012, 12:04 PM Thread Starter
Gene Howe's Avatar
First Name: Gene
Default Need some help locating a blade
Recently BobJ and several others discussed using a 3 3/8 blade in a table mounted router. I thought it was such a good idea that I immediately bought an imperial sized stepped arbor for use with a 3 3/8 blade. Now I can't find a blade with an imperial sized arbor hole!
Does anyone know any place I can find a 3 3/8 blade with a 5/8, or larger, hole?????
Your help would be MUCH appreciated.
Thanks.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #2 of 5 (permalink) Old 05-02-2012, 12:23 PM
The 4" blade will work just fine also I was lucky I got 5 of them on sale for 1.oo ea.
4" Carbide Tip Plate Joiner Blade
Or use the blade below
drill it out just a little bit (on both sides of the blade) with a counter sink bit and it will right into place..
http://www.amazon.com/Makita-792299-...5985269&sr=1-1
post #3 of 5 (permalink) Old 05-02-2012, 12:52 PM Thread Starter
Gene Howe's Avatar
First Name: Gene
Thanks, Bob!
Gene Howe
Snowflake, AZ
post #4 of 5 (permalink) Old 10-20-2013, 06:16 PM
First Name: Dave
Thanks.
Just curious, but why would you want to do such a thing? What purpose will it be used for?
TangoDown3727 is offline
post #5 of 5 (permalink) Old 10-20-2013, 06:54 PM
Hi Dave
Once you make some quick boxes you will need to remove the lid in a safe way.this way will cut off the lid on small boxes or big ones,you can use the table saw but it's not safe.. and the big saw blade/band saw will always leave marks on the lid cut but not so with the small thin blades..almost no sanding needed..this comes from the small blade is turning at 10,000 rpm's.
see my uploads for many pictures of it done...
What do you use to sand the edge of plywood? volunteers Tools and Woodworking 8 04-29-2012 10:28 PM
Squareing The Blade On The Table Saw Jerry Bowen Tools and Woodworking 20 04-20-2012 11:30 AM
Question about saw blades. N'awlins77 Tools and Woodworking 21 03-21-2011 07:47 PM
10" blade selection?? jeep_man Tools and Woodworking 27 04-10-2009 04:57 PM
table saw blade selection blurry Tools and Woodworking 19 03-13-2009 12:12 PM
