fixed, but removable fence stops - Router Forums
post #1 of 18 (permalink) Old 05-04-2012, 03:59 PM Thread Starter
Default fixed, but removable fence stops
I have a bit of a unique problem that im trying to solve. I use about 6 positions on my router fence very consistently, and in fairly random order.
Id like to put some stop in either a t-track, or a miter track behind the fence at these positions, so that i can just push the fence up against them, and not have to measure placement every time (my eyesight is pretty terrible, it takes me quite some time to align a fence to 1/16th).
However, the catch is that when that stop wasnt in use, it would need to get out of the way somehow so that the fence could be pushed over it until it hit the next further back stop. I was thinking removable pegs at those locations, but ill lose the pegs for sure, and want something more fixed, maybe a metal "hinge" mechanism that flips up or something.
Any ideas?
My current table setup below, i have a combo track which the fence slides into. the miter track keeps the fence square, and the t-track is used for locking the fence down and other jogs. Im hoping i can put these "pin stops" or flip stops in the t track somehow. But when not in use, they need to hide away below table depth in the track.
If i had tracks on the side of my table, i could use traditional flip stops, but i dont.
Name:	router table 2.png
jbrukardt is offline
post #2 of 18 (permalink) Old 05-04-2012, 04:08 PM
First Name: Chris
i like the peg idea, sort of like bench dogs ...
how about a few more holes in the base of the fence or on the side of the table or somewhere else out of the way to store the pegs when not in use? you can also put them on strings so they wouldn't go far if they fell.
Chris Curl is offline
post #3 of 18 (permalink) Old 05-04-2012, 04:14 PM Thread Starter
hmm, so heres the second question, if i use pegs, what do i mount them into in the t-track? most t-track accessories have big handles that sit well above the track, im not even sure how you would secure something like a peg holder into a t-track while keeping it flush
Woodpeckers t-track block is the smallest thing ive seen
T Track Block
post #4 of 18 (permalink) Old 05-04-2012, 04:25 PM
Think about a Cribbage board setup that just sits/slides in the tee track and locked into place with set screw..the peg are no real strong but you can use 1/8" or 1/4" dowel pins,then stick up a magnet to the cabinet inside to hold them for you..
This is what I use because I don't have tee tracks. see below
post #5 of 18 (permalink) Old 05-04-2012, 04:35 PM Thread Starter
they dont have to be very strong, theyre just gentle stop points.
Cant quite picture the "cribbage board setup" Just a rail with a bunch of holes in it?
And yeah, i guess i can lock down a 1/4 inch nut with a set screw that would keep the "board" level with the track. Just have to find a set screw of the right size
post #6 of 18 (permalink) Old 05-04-2012, 04:42 PM
" Cant quite picture the "cribbage board setup" Just a rail with a bunch of holes in it? " you got it..
http://www.amazon.com/Rockler-Game-D...6167784&sr=1-1
http://www.rockler.com/product.cfm?p...0&site=ROCKLER
Just drill and tap the hard board to take on a 1/4-20 set screw.
Then when you are done with your router table you can make some cribbage boards to sale or give to some mates..
post #7 of 18 (permalink) Old 05-04-2012, 05:18 PM
pal
pal's Avatar
First Name: Harold
How about small brackets such as from barrel bolt screwed to the back of you fence your small pin could then just be left in there and when you wanted to move the fence just lift the pin and slide the fence.
Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning.
Albert Einstein
pal is offline
post #8 of 18 (permalink) Old 05-04-2012, 05:33 PM
N'awlins77's Avatar
First Name: Lee
JB, how about this. I'm a machine shop mechanic, and I've seen something like this done in a milling machine t-slots. Most metal cutting milling machines, have similar looking t-slots in their work table. I seen one shops set up where they locked down a t-bolt, using a large set-screw where you would usually have a t-bolt, at the end of the table (t-track). Then, they machined precision bars that fit in, but came above the t-slot. Where one end would hit the screwed down t-bolt, and the other end came up high enough out of the t-slot, to hit the plate they wanted to machine. Their plate, being your fence. You would make yourself a series of pairs of these bars, to the different lengths that you want your fence to stop at. They just sit in the slot, sandwiched between the dead t-nut, and your fence. Put, say a 4" long set of bars in there for one setup. Then take those out and put a longer set in, to move the fence forward. Make yourself a nice box to keep your sets of bars in, or put a whole in the ends of them and hang'em on a wall. Mark each one with the length that they set your fence at.
Dang, I think I just talked myself into making a setup like that myself!! Thanks!! LOL
N'awlins77 is offline
post #9 of 18 (permalink) Old 05-04-2012, 08:01 PM Thread Starter
I like it Easily achieved, precise, quickly interchangeable.
Hmm, now to find a good material to make them out of. Im thinking those plastic miter slot fillers, but they wont be quite tall enough.
post #10 of 18 (permalink) Old 05-04-2012, 08:42 PM
You could make a solid stop at the farthest point and use a series of set up blocks to give you every position closer to the bit.
Some Thoughts on Fence Control Gilbear Table-mounted Routing 21 04-16-2010 05:38 PM
A Poor Man's adjustable Positioning Fence Stefang Table-mounted Routing 8 02-26-2010 03:22 AM
Fence and stops setting simplenik Table-mounted Routing 5 12-26-2006 10:08 PM
